Project gutted Formula
Old Jun 23, 2009 | 06:21 PM
  #161
3rdgen92maro's Avatar
There just some cheapy 165r15 Kelly metric radials.
Old Jun 23, 2009 | 06:38 PM
  #162
kierstyn's Avatar
Do the rears look like they will rub with the coil cut? I removed the isolaters and its close that way same tires on my formula almost same setup.
Old Jun 23, 2009 | 06:43 PM
  #163
nik1703's Avatar
Originally Posted by 3rdgen92maro
Heres a few updated pics of the car. Finally got the axle shafts drilled for 1/2 studs and got those installed. Took off the door molding. I Lowered the front coil overs...a bit to much I think but it looks bad *** slammed. Also lowered the rear just took out the spring isolators and cut 1/2 a coil off the spring. Let me know what you think about the new stance.
The LT's just might scrap on everything
Where did you get those wheels/tires man? I want em'!
Old Jun 23, 2009 | 06:44 PM
  #164
It doesn't look like they are going to hit. It seems like there is enough space for them on my car. I sure hope they don't
Old Jun 23, 2009 | 07:08 PM
  #165
96FirebirdFormula's Avatar
how soon till its running down the track?
Old Jun 23, 2009 | 07:10 PM
  #166
kierstyn's Avatar
LOL mine tuck pretty good. I had thought bought cuttin a coil off but kinda worried it would rub. Also your car looks good! All these threads about weight reduction has had me going crazy on mine just got the dash back in! Lots of weight can be taken out here and there! Everytime I think Im done a new thread pops up and gives me another reason to rip something else out!
Old Jun 23, 2009 | 07:24 PM
  #167
Hopefully pretty soon. I just have to get the trans and everything to go with it. Im hoping to have it atleast moving under its own power in the next few months.
Thanks
So they tuck more then mine do? I was thinking about cutting a little bit more off the rear but idk. You think the front is to low or should i leave it?
I know how that is. I have thought i was done ripping stuff out numerous times..then someone posts up something else that can be taken or cut out...so i have to do that to lol. Once the weight reduction bug gets you its all over. lol It all started with taking out the front sway bar and AC lol
Old Jun 23, 2009 | 07:36 PM
  #168
kierstyn's Avatar
I can get like 2 fingers between there so its close. The front looks good on urs Id drive it and see how it does. Then when you get ready for racing try to set it up for the best weight transfer.
Old Jun 23, 2009 | 07:58 PM
  #169
AChotrod's Avatar
Man Looks kick ***!!!Great work!!
Ive finally started doing some to mine!
Old Jun 23, 2009 | 08:03 PM
  #170
That's pretty much what I'm going to do. If it drags everywhere ill just crank the QA1's up a bit.
Old Jun 23, 2009 | 08:06 PM
  #171
Thanks man I'm glad all this work is finally paying off. You better be carefull...or before you know it you will have a weight reduction addiction and your formula will look just like mine LOL. BTW i love the GW's on your car...care to tradelol
Old Jun 23, 2009 | 10:24 PM
  #172
Well i started stripping the under hood harness. What a PITA. Does anyone know how to disconnect the under hood body harness from the bulk head connector on the drivers side thats under the dash??
Old Jun 24, 2009 | 12:27 AM
  #173
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm pretty sure it doesn't disconnect. I've done it a few times. There's about 6-8 plugs under the dash that you have to unplug. Prepare to be frustrated if all of the dash and driver seat are in there. A flat head screwdriver helps. The giant bulk head has a screw that holds it to the firewall though so you have to take it out or else it won't budge.
Old Jun 24, 2009 | 02:20 AM
  #174
that sucks i was hoping it came apart. Man oh man are those under dash plugs a **** to get out. hopefully i can finish up the harness tomorrow.
Also what is the aluminum box with the 2 connectors under the left side of the dash for? Is it ABS stuff?
Old Jun 24, 2009 | 11:57 AM
  #175
AChotrod's Avatar
Thanks! Im not going to cut it up or anything. I want it to look stock besides the missing back seats. Just bolt offs and when I can afford it Ill start with $$ Mods like a k-member and drag brakes
No deal on the trade........
Old Jun 24, 2009 | 02:14 PM
  #176
litch2004's Avatar
if im not mistaken that box is the airbags. remember if it is a yellow plug it is airbag stuff.
Old Jun 24, 2009 | 02:55 PM
  #177
Here is a pic of the box I'm talking about maybe it will help.
Also any ideas on how to get this connector apart??
Old Jun 24, 2009 | 03:38 PM
  #178
OWN3D BY MY PROF!
I knew what box you were talking about before you posted the pictures. I remember asking someone and them telling me, but I don't remember. I'll search around for you. I'm pretty sure on the other one it has a bolt that holds it together. You have to get in there with a small ratchet and undo the bolt. It's been a while, but I think I'm correct.
Old Jun 24, 2009 | 06:22 PM
  #179
thanks man i would have never found that damn bolt in the middle of that connector. who the hell designs dumb S%!$ like that.
Old Jun 24, 2009 | 06:27 PM
  #180
Well the engine and underhood body harness is almost done. Just have to finish wrapping it up in some electrical tape...the old wire loom looks like complete crap. Then i get to move on to the interior harness...what fun.
