affordable place to ac delco o2 sensor?
These are from http://www.rockauto.com/catalog/raframecatalog.php Not sure which ones are correct for my car (97 formula) The o2 I know is shot is the drivers side one mounted in the header. I don't mind replacing both though.
ACDELCO Part # AFS75 More Info {#19178930, 213509, 25171579, 25312184}
SENSOR,HTD OXY(POSN 1) IN EXH MANIFOLD/CROSSOVER; w/o LEADED FUEL EMIS EXPORT (NM8) or NON-HEATED O2 SEN(ABN)
ACDELCO Part # AFS123 {#12587214, 19178924, 25312207, AFS116}
SENSOR,HTD OXY(POSN 3) POST CONVERTER
SENSOR,HTD OXY(POSN 2) PRE CONVERTER
ACDELCO Part # AFS97 More Info {#19178921, 25312196}
Which of these AC Delco O2's are the ones I need for a 97 Formula? I can't figure it out... Plus I'm at work and my mind is all over the place. Thanks guys, sorry to be asking such a newb question
www.getgmparts.com I purchased my o2 from here, making sure that I specified I only would accept an Ac Delco sensor. I was sent a Delphi, is this made by ac delco, will it work fine or should I cause a stink. I am willing to do whatever
