ASR off/ABS INOP lights stuck on after removing traction control.
Well I removed my traction control and now the "ASR off" light and "ABS INOP" lights are both stuck on. I could see the ASR one sticking on but why would the ABS light come on? As far as I know I didn't screw with the ABS at all?
My "abs INOP" light has been on ever since I changed my opti I don't know why it came on either. If I were you i'd just pull the bulbs.
The traction control system works with the ABS, so if you loose traction it de-throttles the engine and can modulate brake pressure at the same time (in case you are sliding and the driver hits the brakes), so if you disable traction control it causes an ABS fault also.
Will do. Thanks!
where is the ground you speak of? under the dash, or under the hood?
