nitrous is done and testing this week
Old Sep 20, 2009 | 09:23 AM
  #61
LS1 SPEED's Avatar
thanks..
yeh it was under 12 cruising, but WOT the Caspers volt blaster was keeping it o.k
I notice more driving home when everything went dim, speedo and tach jumping. I would then drive for a mile and boom voltage come back, then drop again. This damn alternator has been redone twice by a local place and lets just say the 3rd time they will not be the doing it.
I feel this has been part of my off idle stumble issue all along as well.
always something with these toys
Old Sep 20, 2009 | 09:56 AM
  #62
BOLO's Avatar
Nice results for first time out testing on spray. Despite the air temps, you're car seems to be putting down good numbers as always. Hopefully you get those electrical issues sorted out, which I'm sure you already have. And by your next outing, I'll try to come out and hopefully have my car running too.
Old Sep 20, 2009 | 10:13 AM
  #63
FASTFATBOY's Avatar
Originally Posted by LS1 SPEED
thanks..
Well I unloaded mine off the trailer( a buddy came and got me) I stepped on it out in the street and it started charging, the needle bounced a couple of times then quit charging. I broke out my manual, the plug in the back with the key on make sure you have batt volts on the wire in that plug from the gauge cluster. Mine does, bad alt.
Old Sep 20, 2009 | 10:18 AM
  #64
LS1 SPEED's Avatar
thanks Butch
I hope to see your car out again before the year is up.
FATBOY..thanks for the tip
Old Sep 20, 2009 | 11:01 AM
  #65
flyinZ's Avatar
I've never had any luck with a reman. alternator, just dont last over a year or two. I might just have to buy a GM unit...that wont be cheap,lol.
Almost had you a 9 sec pass, Larry. Next time you'll get it, I have a feeling
Old Sep 20, 2009 | 11:12 AM
  #66
LS1 SPEED's Avatar
I had the stock one done for higher amps, but as mentioned it doesn't seem to be working well.
I feel good about going to Byron in a couple weeks with 0 changes other then a full bottle I will get my 9 sec slip.
GLD never is my PB track
Old Sep 20, 2009 | 11:24 AM
  #67
Stroked96Bowtie's Avatar
Killer 60ft for being on the small shot. Did you guys make any adjustments from the dyno to the track on nos (timing, fuel pressure, etc.)? Just curious if you did that with the numbers off of the dyno. Do you think you are loosing any power on the bottle with that loose verter? Reason I ask is I just had to tighten mine way up from a 3600.
Old Sep 20, 2009 | 11:26 AM
  #68
AChotrod's Avatar
Sweet deal man! That .09 is yours next time you hit Byron. Your car 60s awesome!
My trailer fell through and I didnt want to drive the car there and test for the first time, without a 4 syre ride home.lol
Old Sep 20, 2009 | 11:36 AM
  #69
LS1 SPEED's Avatar
other then leaning it out just a touch it's the same as the dyno
I will try locking it next time out to see how it responds.
We will get to Byron soon to work more on the car after I get a good alternator. I will give you a heads up Mike to get out with us.
thanks guys
Old Sep 20, 2009 | 12:00 PM
  #70
chrs1313's Avatar
sorry to see you not make it...the track was there, but the air could have been better
NA 10.86@123 1.41 60 ft
N20
I want to work some more on getting the most from the 150 shot both traction and tune wise and move from there.
I did not go over the plugs Fri, but got the A/F in the 11.8-12.2 area and I was very happy with the results for the 1st time out
1.36 60 ft ..still more in it
6.40 1/8
107 mph 1/8
10.09 ET
132.5 1/4 MPH
I plan to put a little more timing in it, play with shift points and keep working on the window switch to get it to 60ft harder...went 1.41 on HP the same night.
I was a little worried this night so I tightened things up after Z8s put his LS1 street car on the bumper. I drove the car to and from the track and wanted to make sure I could make it back the 1.5+ hr trip.
I have to getting a alternator issue sorted out here and be back at the track in a couple weeks.
nice runs larry i new it looked pretty good from the stands...wasnt sure if you got the 9sec pass or not...let me know when you go to byron and i will take my turd out...
rob seems to have hurt his rear...we think he spun an axle and broke the spool (aluminum)...passenger side seems like the only side engaging...when he gets on it is drives the car to the left...
and i saw that bumper pass, he pedaled it decently but i bet those headers are crunched...there was some huge sparks, glad it wasnt the oil pan...
Old Sep 20, 2009 | 12:55 PM
  #71
robsquikz28's Avatar
Larry, that **** is flyin man, damn good job and cant wait to see a vid.
Old Sep 20, 2009 | 01:00 PM
  #72
Z8'S's Avatar
Thank goodness for the UMI K member with the double row on the bottom it protects the oilpan .but it is a little lighter now Even with all the airtime it still went a new PB1/4 and 60ft 1.325 probably on the rear tires Exhaust is all good.
Old Sep 20, 2009 | 01:30 PM
  #73
Puck's Avatar
Looks like its coming along great. Funny how the little gremlins seem to show up no matter what precations you take - gotta love performance vehicles.
Not bad for a streetcar
Old Sep 20, 2009 | 05:40 PM
  #74
LS1 SPEED's Avatar
thanks Chris
I did not get to talk to everyone as much as I wanted too...I ran the car with not much cool down as you seen and otherwise ran the 2010 a coupe times...almost getting landed on by Z8's
I hope Rob did not do much damage and get the ride back together quickly.. I will let you guys know the plan for Byron when I know.
and yes..if a K-Member is in min I suggest UMI which protect the oil pan
thanks Rob
I do hope we got video which I can post as well.
PUCK ..thanks man..it isn't a problem unless it's modified
Old Sep 20, 2009 | 09:30 PM
  #75
LS1 SPEED's Avatar
Default pics
1.41 60ft on HP ..thanks Yank/FLT
Old Sep 20, 2009 | 09:37 PM
  #76
BOLO's Avatar
Awesome pics/ Awesome car as usual, Larry.
Old Sep 21, 2009 | 08:36 AM
  #77
Formula383's Avatar
Congrats Larry! You'll have that 9 in no time man.
Old Sep 21, 2009 | 10:42 AM
  #78
LS1 SPEED's Avatar
thanks guys
I know the 9 will come next time out for sure.
Old Sep 21, 2009 | 04:18 PM
  #79
flyinZ's Avatar
New pics for my desktop, yea! Looks great as always man
Old Sep 21, 2009 | 04:29 PM
  #80
Tony Shepherd's Avatar
Congrats Larry! Easy 9 coming!
