Cutout vs. TD's
IMO Xpipe sounds the best but some people say H.. you are talking 2-3rwhp MAX between the two.
a TD is expensive if taken out the back.. cheap if its dumped.. loud if its dumped and cant quiet it down..
cutout sounds like everybody else car but you can make it quiet if you want by running through a quiet exhaust.. cutout is much cheaper in all situations.
The cutout sounds like absolute **** compared to a TD's setup. I would imagine the X would scavenge much better than a Y setup making it beneficial. Also running dumped TD's is much lighter than a Y-Pipe/Catback setup. Ditching my 3" ORY and Magnaflow for my dumped 2.5" TD's shaved almost 30 lbs. off the car.
WRT the cutouts.
When I had a single 3" cutout on the Borla catback, It gave me less than a 6RWHP gain on the dyno. This is due to the cutout being so far back that it becomes less effective. IMHO, cutouts should be around 18" behind the long tube collectors for best power gains.
My cutouts are placed where I stated above (see sig for pics). When I open the cutouts, I can feel a gain in the higher RPMs, but the lower RPM power band does soften up a bit.
Edit: Fixed
Last edited by wrd1972; Oct 14, 2009 at 02:38 PM. Reason: Was high on crack when posting
WRT the cutouts.
I will simply plead WTF on that one.
Note to self, Do not smoke crack then post on this board.
