timing chain question...and cam installation Q
I'm installing a new cam into a new motor and the motor is a 93-94 lt1 timing chain. I'm installing a reground cam from a 97 and I was wondering if I buy a new chain, can i mix the sprockets: Basically, can I use the 97 camshaft sprocket with a new chain and the 93-94 crankshaft sprocket? I do have the 97 timing chain cover.
I wasn't sure if the teeth count were different or if the chain and sprockets had a different width. I'd like to only buy a new chain and call it good. The sprockets all look good to me.
Also, when installing the cam and lifters and everything, are there certain steps I should follow. I already installed the cam, I just lubed it with a little bit of oil and slowly pushed it in. I obviously don't have the timing set up or anything because I still need to buy a new chain and I haven't reinstalled the lifters or anything yet.
I've heard some things about pumping up the lifters with oil and I'm not sure what I should be doing. And should I try to drain the lifters of all the old oil?
Do not mix timing chain parts. Buy the whole set and replace it as a whole. The parts wear into each other, and you will get premature wear if you just replace the chain.
I didn't pump up my new lifters, but I did clean them very well. Soaked them in mineral spirits and dried with compressed air, then gave them a light coat of oil before installing.
If you are running a non-vented opti, you cannot use anything but the cam gear for it. That means a late model cam gear won't work (it won't turn the opti).
No, I'm using the late style cam sprocket because I will be using my 97 reground cam with the long dowel pin and I'm using a timing chain cover from a 97 and I'm using a vented optispark. I just needed to know if there was a variance in the thickness of the sprockets or something weird.
Tell me why I should replace sprockets if there is nothing wrong with them? The chain I understand, but not the sprockets.
BTW, what the heck is spirits? Do they sell that at an auto parts store?
You replace the sprockets due to the fact that they wear with the chain. It is extra insurance when doing a project like that. Why not spend the extra $100 or so to be safe?
Mineral spirits may be available at the parts store, if not any hardware store will have it in the paint section.
The 93-97 crank sprockets are exactly the same. You cannot eyeball wear on the sprockets. LT1s suffer enough from timing chain slack and new sprockets and chain are the best solution. If you put a new chain on old sprockets, the chain will immediately begin to wear to the pattern in the old sprockets. Is that what you really want?
