LT1 balancer Help
Old Dec 21, 2009 | 05:48 PM
jaycenk's Avatar
Default LT1 balancer Help
I need a broached hub and balancer for my 383 build. The motor is internally balanced so I need a neutral balancer. What are my options? I found a TCI balancer and hub http://www.summitracing.com/parts/TC...7/?image=large
I also found this hub on jegs http://www.jegs.com/i/JEGS/555/51609/10002/-1#
and this balancer http://www.jegs.com/i/JEGS/555/51606/10002/-1#
anyone use these? I need one very soon so it would have to be shipped before thursday. let me know what other options there are for me. Thanks
Old Dec 21, 2009 | 06:32 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
I could get you an ATI balancer.
These are SFI approved & also available in lightweight aluminum as well as in 10% underdrive versions.
Feel free to call & discuss.
Old Dec 21, 2009 | 06:49 PM
Paul Bell's Avatar
That's MISTER MODERATOR
This thread is probably gonna be moved to the "parts wanted" section, where nobody will see it.
There's another recent thread on this at: https://ls1tech.com/forums/parts-wan...-balancer.html
Old Dec 21, 2009 | 06:56 PM
jaycenk's Avatar
All I need is a nuetral balancer. you have a part # and a price? how do you take your orders? I found an ATI balancer on summit ATI Performance Products 917271. little much. I'm running 383 N/A and 6300rpms. What do you sugest?
Old Dec 21, 2009 | 07:21 PM
ls2pontiac's Avatar
Self-Admitted Scammer
+1 for lonnies, bought my balancer off him and had it in 2 days..same with a fuel pump among other things
Old Dec 21, 2009 | 07:22 PM
Paul Bell's Avatar
All LT1 engines have neutral balanced harmonic dampers.
Old Dec 21, 2009 | 08:28 PM
jaycenk's Avatar
Actually there were some that were weighted. I have no idea what they were in or why they were like that but I came across an article at GM hightech that tells you to always check.
http://www.gmhightechperformance.com.../photo_39.html
Not that I need one.
My question is more or less were do I find one with a broached hub that I can get before christmas.
Old Dec 21, 2009 | 08:47 PM
01fxst's Avatar
I thought the LT1s were balanced with the flywheel. I had to have my flywheel neutrally balanced when I did my 383 build since the new motor was internally balanced. I'm not sure shoving a balancer on the front of the motor would have done the trick.
Old Dec 21, 2009 | 08:48 PM
VF1000R's Avatar
Summitt , may have to call them.
Old Dec 21, 2009 | 09:11 PM
jaycenk's Avatar
Thier mostly internal with a weighted flywheel or flex. Just a very select few have wieghted balancers. Must have been the reject motors that GM balanced them by weighting the balancer insted of taking it out of the crank. IDK
Old Dec 21, 2009 | 10:20 PM
Paul Bell's Avatar
Interesting about that weighted balancer. As crankshafts are spin balanced as a single piece in a jig to a computer program, they should all come out matching. They certainly also spin the balancers to check their balance and any that aren’t balanced due to casting or machining issues, they'd subtract weight to zero it. I do recall seeing some hubs with drilling in them to balance them so maybe they're balanced as a set. In picture # 41 in the article, this is seen. None of the photos, show any added weight on the balancer or the hub. Also, if the crankshaft relies on a weighted balancer to be balanced, they’d have a key way in the balancer hub bore and keys installed to positivity locate it on the crank. I think the article may be incorrect. It is common practice to install the balancer hub with the arrow pointing up at #1 TDC but being neutral balanced, it won’t make a difference if it’s off.
Then again, we're talking about GM, one never knows what might happen on a production line to "keep things moving".
It does appear that all aftermarket harmonic dampers are un-weighted neutral balanced.
In what way do you mean you need a "broached" balancer?
JEEZZ, I wrote "balance" 15 times. Make that 16 times now.
From The American Heritage® Dictionary:
(transitive verb: broached, broach·ing, broach·es.)
1: To bring up (a subject) for discussion or debate.
2: To announce: We broached our plans for the new year.
3: To pierce in order to draw off liquid: broach a keg of beer.
4: To draw off (a liquid) by piercing a hole in a cask or other container.
5: To shape or enlarge (a hole) with a tapered, serrated tool.
(noun)
1: A tapered, serrated tool used to shape or enlarge a hole.
2: The hole made by such a tool.
3: A spit for roasting meat.
4: A mason's narrow chisel.
5: A gimlet for tapping or broaching casks.
6: Variant of brooch
I pick number 3!
Old Dec 22, 2009 | 12:36 AM
jaycenk's Avatar
(noun)
I pick number 3!
Maybe I wasn't clear on the balancer but I am looking for a hub and balancer were the hub is already broached for the crank key. Just figured I'd ask to see if anyone knew off the top of thier head were to get a good balancer that didn't cost close to $400. I am going to just call TCI in the morning and find out for sure if the hub on thier balancer has a key way.
Old Dec 22, 2009 | 01:32 AM
Paul Bell's Avatar
AHH, gotcha. From what I've seen, all aftermarket LT1 balancers have the keyway cut in the crank bore.
Did you see this?: https://ls1tech.com/forums/12647905-post2.html
