Guys with 4 hole throttlebodies and a single plane, wipers?
I know I have to cut the cowl back, but does it interfere with the wiper mechanism?
I am about to do this swap, new hood 1000 cfm 4 hole, carb hat etc. New converter(looser) see what this pig will do!
what single plane are you running? from what ive read, if youre running a victor E you should be able to put a 4barrel TB with a carb hat on without cutting (its like 3/4" clearance) its when you put a nitrous plate in that you have problems. i could be wrong though
Its not the height, its the location....the carb flange is under the cowl.
I have a super vic, it has to have a 1 inch to 1.5 inch spacer to get up over my fuel rails for the throttle linkage to work. Then I have to put a blow through hat on to plumb to my MAF.
There are some pics and good info in here
https://ls1tech.com/forums/dynamomet...-b-change.html
Also see here
https://ls1tech.com/forums/drag-raci...car-motor.html
Mine is a streetcar, I need wipers
Also see here
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
to do it you need to have someone who can truly fabricate, I cut away, and Randy welded up
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
