LS1 Lid + LS1 rad support + stock hood = DONE
Old 12-31-2009, 11:21 AM
SS MPSTR's Avatar
Wow. Very sanitary job. I'm going the same route, with a very similar set-up.
Old 12-31-2009, 11:26 AM
LS1 SPEED's Avatar
I really like this and it appears to be a job very well done.
looking forward to seeing the pics of it apart and underside
thanks for sharing
Old 12-31-2009, 12:24 PM
AChotrod's Avatar
thanks for sharing
X2 this is the first time Ive even been interested in thinking about a swap.
Old 12-31-2009, 01:23 PM
JoeliusZ28's Avatar
Originally Posted by transam5.7lt1
Did you see any difference in power/throttle response? I mean seat of the pants feeling?
couldnt tell you because the streets are full of snow and salt right now and im on storage insurance for the winter, the car isnt going anywhere until april.
I believe the LS1 radiator support is a direct swap for firebirds with the WS6 hood. Or at least its a lot easier.
I am working on a write-up for this install. i'll post it along with more pictures later today.
Old 12-31-2009, 02:36 PM
wrd1972's Avatar
I will do this sometime this year and measure MAP readings to see if there is truly a gain or not.
Old 12-31-2009, 03:04 PM
VIPRETR2's Avatar
I'm interested in more detailed pics as well. I just bought a lid setup and a SSRA for the 96 Ram Air. Your setup is the cleanest I've seen to date. Good job,
Larry
Old 12-31-2009, 03:52 PM
Vicious95Z28's Avatar
Originally Posted by JoeliusZ28
I will take it back apart and get some detailed pictures tomorrow.
Im gonna say right now though it was a lot of work, but alot of it was trial and error. I spent way more time on the radiator support than i did fabricating the lid.
So, you still had to slice a big notch out of the metal support right?
Old 12-31-2009, 04:05 PM
JoeliusZ28's Avatar
correct
Old 12-31-2009, 05:22 PM
BlackLT1Z's Avatar
Not so much a direct swap but probably easier as it has more clearance. We tried it. I think I know what you did. Did you cut the bottom of the bolt holes out of the plastic? I had all the parts to do this myself and decided against it for some reason. I ended up getting a Ultra Z hood and using the LS1 FIPK II. Look at my pic below for the way it looks.
Old 12-31-2009, 06:41 PM
Z-RATED94's Avatar
Nicely done. Obviously my friend you are not a hack!!
Old 12-31-2009, 06:55 PM
daniel6718's Avatar
id like to know how...because ive done this 3 times and trimmed them until they were almost paper thin and you have to trim the whole bottom of it to make it fit and i still couldent make it fit
  #32
1badzee's Avatar
That's exactly what I've been looking to do.. Very nice setup man!
Old 12-31-2009, 08:08 PM
  #33
silverfoxSS's Avatar
Does SLP make anything like this for the B Body? I love the look. If they don't...would THIS fab work?
Old 12-31-2009, 11:47 PM
  #34
JoeliusZ28's Avatar
are you setting the filter and lid down into the core support? Making the lid clear was much more of an issue (actually i am still trimming the hood for it) than making the radiator support fit. When i was done cutting the radiator support to fit, i threw it on (less the lid) and my hood closed with no hiccups.
The trick is to do the lid WITHOUT the radiator support and then make it fit around that setup. using the raised filter mount comes no where close to fitting.
I took a bunch more pictures today and got part of the writeup done. Now that i took it apart, i think this will be very easy for you guys to replicate once you see where to cut. What took me forever was all the trial and error.
Old 01-01-2010, 02:03 AM
  #35
Blackbird97's Avatar
Wowo that looks like it was meant to be there! Great job! If I didn't already have the factory ram air box, I'd definitely want to do it up like that!
Old 01-01-2010, 09:19 AM
  #36
97LT1's Avatar
My question is how many have pulled off something like this with a meziere HD pump? It barely clears my fan shroud at this point (trimmed) , but not sure if it is just a matter of moving things and cutting. Nice job btw. Looks factory and that's a great thing.
Old 01-01-2010, 11:11 AM
  #37
z28camaross's Avatar
wow this looks nice!!! great job man!
and happy new years
Old 01-01-2010, 12:22 PM
  #38
Bowtie4life's Avatar
I know what ya mean about trial and error and a lot of trimming, thought it was probably tougher getting that to fit than it was for me to fit the ls1 ws6 raised base under my ram air hood. I would think that getting the normal base with a lid should be easy with a ram air hood. That's a great job you did, looks really good.
Old 01-01-2010, 12:26 PM
  #39
Ironxcross's Avatar
Now you have to get some kind of ram air
Old 01-01-2010, 12:46 PM
  #40
86formula's Avatar
may end up doing this with a single plane intake a 90* elbow
Quick Reply: LS1 Lid + LS1 rad support + stock hood = DONE
