Changing over to a vented Opti??
Old Feb 3, 2010 | 02:52 AM
GoFastKid's Avatar
Default Changing over to a vented Opti??
What is required to change/do to go over to a vented opti from a non vented?
Old Feb 3, 2010 | 02:56 AM
Z28Camaro30Ann's Avatar
You cant "actually" do that. You would require an opti from a 96-97 LT1 and they will not work on a 93-95 LT1. HOWEVER, you can buy a cap/rotor kit from MSD that converts the 93-95 into a semi vented setup. It will help, but as far as making it a vented setup like the 96-97, I wouldnt even attempt it.
I have heard about some people drilling holes and welding tubes on to do it, etc....I wouldnt advise that. Optis are sensitive enough as it is....why risk messing it up and making it worse?
Old Feb 3, 2010 | 02:59 AM
RamAir95TA's Avatar
95+ optispark. 1104032
95+ timing chain setup (specifically the cam sprocket, the crank sprocket is the same, but you'll want to replace everything, not just the sprocket). (chain - 10128485, crank sprocket - 10128346, cam sprocket - 10206039).
95+ or aftermarket camshaft (due to needing a longer pin and deeper cam snout nose).
95+ vacuum harness. 12555323
95+ electrical harness. 12130319
95+ timing cover. 12552426
95+ vacuum fitting. 14082470
Old Feb 3, 2010 | 03:04 AM
Wow...so I stand corrected but HOLY HELL that is alot to change and alot of work just for a vented opti!
Old Feb 3, 2010 | 03:36 AM
gregrob's Avatar
Yes you can, as Joe's post shows.
The MSD cap n rotor is definitely the way to go though.
Not sure what you mean by "semi-vented". That's not really possible, you need a hose to let fresh air in AND out. The MSD has both...
Old Feb 3, 2010 | 11:09 AM
96lt1m6's Avatar
LOL, Joe's on the ball this morning.....
in addition to this list the stock cam will work all you need is the dowel pin from a 95-97 and swap...while you are in there doing this, it would be a perfect time to instal a new timing chain.....looks like alot of work but it is not.
Old Feb 3, 2010 | 12:36 PM
RamAir95TA's Avatar
Sorry bro, but you need a new cam. It's not just the dowel pin.
Old Feb 3, 2010 | 09:33 PM
4SFEDZ's Avatar
i have everything but the longer dowel pin, anyone know where i can get one?
Old Feb 3, 2010 | 10:18 PM
shbox's Avatar
Machine shop.
BOLO's Avatar
All that in the list or, just buy the MSD opti, already vented. And no need to change anything else.
Old Feb 3, 2010 | 10:39 PM
SoxXpupPeT's Avatar
just get an msd cap and rotor
