poll le2 vs ai 190 vs new trickflow
96 like I said your car runs very well and is also a well thought out combo. When I can get my 60ft down to a respectable number and see what the car will really do. We can talk. As it is My car Out MPH yours but you have A better ET. PS I know all about the weight difference.
Hope to see you at the track again in spring. This time Ill bring keys lol
Oh I also changed cams since the last time I ran my car, Lloyd thinks the new cam is good for another 2mph and .2 tenths. I also added Strange DAs & springs upfront, comp 3ways out back, drag bar, and putting bigger tires out back.
You lost 20rwhp from that? I would have taken that bitch back out and found another option. I just dont think your story holds water pal.
How about you put a set of AI heads and flow them each port individually. The Machine is only as good as the guy that made the program. Im not saying its going to be way off, who knows it might be right on. But you cant really throw that graph up to slam some ones dick in the door when you dont have one for the current heads your running.
AI puts out and awesome product. And if they wouldnt of treated me like **** the first time I called them they wouldve gotten my order, Instead I got off the phone with them called LE and ordered from him. I dont care how many tire kickers someone gets in a day when your in this Biz every call is a potential customer.
I honestly think if AIs customer service changes Ill run a set on my other car.
op I VOTE BUY THE TRICKFLOWS AND SEND THEM TO LLOYD
Have him port them and custom spec you a cam
Super nice guy to deal with and you cant go wrong with a Texan Hot Rodder
My numbers might be off a bit but not by much.
Bone stock 10 bolt VS a DANA S60 with a 9.75" gears. 35 spline axles, and a Detroit True track.
Its the biggest beefiest rear you can get. Ford 9" typically loses more than the S60, but is lighter. I could throw in a spool and get some of that HP back and save some weight but that will take away from the cars streetability.
The closest AI car to mine that brought up why I might have power advantages in the rest of my set up, Im saying I have things that take away some of that. Thats all.
I was mistaken on the actual numbers of the rear when I posted its been a while since I looked at the weights and dyno. So maybe 1-2mpg gain.
Im not sayin either are a handi cap because the ETs are better and Pc of mind is there.
The diff isnt a hurdle although it does rob HP.
Greg mine lost bout 14 with the rear, the clutch is what brought it down another 9.
I work on a car thats puts down tremendous power and it has gun drilled 40s in a 9" it runs 200+ in the 1/8 with .900 60'
why the hell would you put 40s in a street car? you rea;ize how much that rotating wt kills you? unsprung too. there is no reason for you to need 5/8 studs either...come on man your slitting your own throught.
