poll le2 vs ai 190 vs new trickflow
I work on a car thats puts down tremendous power and it has gun drilled 40s in a 9" it runs 200+ in the 1/8 with .900 60'
why the hell would you put 40s in a street car? you rea;ize how much that rotating wt kills you? unsprung too. there is no reason for you to need 5/8 studs either...come on man your slitting your own throught.
The would be a horrible rear end for a street car, and would slow it down for no benefit at all.
The point of what I said was that the Dana I weighed was as heavy as it can get minus solid axles vs gun drill and a Detroit locker.
While on the subject though, the 40 spline Dana axle with the axle bearing pressed on and wheel studs installed weighed 2lbs more than a stock 10 bolt axle with wheel studs. The 40s were gun drilled.
In the end LOTS of places do great work, and like mentioned above its a total package that make cars fast. Not just a set of heads. Ive seen both Terrible and great results form LE and AI on this site!
If that theory is correct there have been far more LE buyers that have failed "in the execution than actual parts..."
P.S. EB porting has done some good things in years past. He just hates mdacton because he's such an *******.
Is it the extra cubes?
The LT4 heads?
The bigger valves?
your awesome driving skills?
I sure would love to know your secrets to a solid roller 396 running low 12s and 11.99 on a full moon
You know as well as I do LPE > all.
you like your niceties...good for you, great excuse for a weak pos
