help pick turbo cam choose inside
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
lt1 396 stroker splayed lt1 afr 210cc comp port #1101 victor efi port matched to heads 1206 gasket elbow with 90mm tb je custom -31cc pistons lunati 5.85 forged rods and callies forged crank Pro turbo kit just a 4 inch dump pipe no exhaust 160 lb. Injectors running e85 fuel and a FAST ecu through th400 3800 stall converter bolt 3.73 gears 28" race weight with driver 3400 lbs and 1.6 roller rocker I want max effort 20-25 lbs boost high hp pt88 trailered drag car street once in a blue moon on a saturday night maybe once a month if that
cam spec options these are all solid roller
#1 (244/247 .664/.664 115)
#2 (242/244 .627/.634 115)
#3 (258/252 .688/.680 115)
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
these are 3 different cams given by 3 different TOP cam companies with all the ness info given to then im the builder i build my own engines when it comes to cam grinds this is it all 3 companys got the same info im not saying im going on everyones opinion an thats the one ill pick im just seeing ppls intake thats all ya i know the converter is tight but it was a bilet cover 3800 from art carr i purchased for another motor i still had around and only put 3 passes on it at the track besides the 4 on the street lol thanks guys and ya the motors going to spin up to 7400-7600
My race weight Sunday was 2800lbs still needs hood and alot of stuff in it. My stall is same, and for a cam I have a 232/234 I think .570 at 114
I run 1/8 and goal is <7000 rpm and 5.9 I went 6.11 with 16 psi so I think I have more left to allow me to reach 5.9. Since I am o ringed I can go 22 psi and controller is a 22 psi so it is ready. Mine is a 377 stock bore LT1. I use the stock computer and right now still maf tuned. I hope you will be tuning your own...
I am not sure your goal so tough to even comment on what you could or should look at. Will you run 1/8 or 1/4? Brake or foot?
I m foot and I don't use a 2 step yet, I may need it to get in 5's since my launch rpm is critical. Also will you use meth? IC size?
Look forward to hearing how your monster does. And as metioned size is less important with boost and aften loses more than it gains.
Good luck
My block has a girdle and my injectors are 93 lbs. I also have dual nozle meth running M7's in each.
I used striht -20 wiper mix and IAT were 80 degrees F on a mid 50's day. The IAT's actually drop slightly an stay constant for the 1/8th. Car has 4 link nd I run 31 x 10.5
Personally I would go smaller and go with number 1 if I were you, and change gears to keep RPM ~7000 (Especially if it isn't 'capable' of 7400).
I am not familiar with the flow of that turbo but seems you will need ~130 Lb/min and I would want to keep the setup in the turbo's sweet spot.
I have twin 70's.
Good luck
PS and my opinion is worth every penny you paid for it?
my valvetrain is set up for 8000 rpm nothing cheap titanium and large seat preasure so on too much to list as for the pt88 flows 125lbmin and the gt88 flows 135lbmin im also running full quarter mile if i spin to low ill be bouncing the rev limit threw the traps like i did with my blower car
Your choice will cost alot of money and be VERY disappointing. I would talk to others who have done turbo systems that WORKED. You want to keep the turbo in an area that it is efficient and that is not at it's maximum flow point.
Good luck
