Clearance issues with Milodon 30909 oil pan?
I installed a friends motor the other day. He went with the 30909 pan. It is now within millimeters of touching the rack. I might be able to slide a piece of paper in between and that is it. Anyone else have this issue in their car? Motor mounts are newer and poly so I ruled that out. Pretty stumped.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I have the stock k member and the oil pan hit the rack right now I'm building a 8 mm flange to put between the motor mounts an the engine. It should be work I'll let you know.
what I don't understand for what reason is not a problem for other people since it only happens to a few and for why I read in others forums this oil pan it's called the sleeper for that reason
part of moding
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
If you get into shimming the trans mount then you will also have to measure the pinion angle. As stated, no need to do this unless you experience any sort of vibration that wasn't there before.
