align honing for crankshaft?
what i know align honing will free up some rwhp and makes the crank rotating easier and freeier.
thanks.
For those who don't know, a small amount is removed from the caps and then the hone is used to bring the mains back to round.
Different size bearings are used to fix clearance issues betwean the crank and the bearing.
Doing the above right will free up HP and help the bottom end to live. Way too many short blocks are slapped together. The resulting performance reflects it too.
thanks
Even some of the biggest half *** back woods boys I had ever met in my life could take an engine with caps that didn't match and keep the bearings, crank and rods in it for several dirt track seasons. I couldn't belive some of the **** they pulled or how the hell it stayed running, but it did. If I had done **** like that, it would blow up before I turned the key.
145-150 is REALLY REALLY LOW, lest test I have seen on a 180K mile LT1 was 185psi and an ester based cleaner in the oil raised that one up to more like 195psi
The minimum that I would do if I had the bare block is...
1. Align hone.
2. Square the deck.
3. Replace the cam bearings.
4. Replace the freeze plugs.
5. Polish the crank.
6. Install ARP rod bolts.
7. Resize the rods.
8. Balance the rotating assembly.
9. Use good quality rings and bearings.
You only get one chance to do it right!
1. Align hone.
2. Square the deck.
7. Resize the rods.
1. Align hone.
2. Square the deck.
7. Resize the rods.
Have it checked. If your doing a rebuild you replace bearings, rings and change cams at a min. If you have some more funds, change pistons and rod bolts and maybe get the rotating mass balanced.
It's utterly retarded to think a block would be "a good one or not" if the same crank was used in the same block for a stock rebuild where no abnormal wear happened on the previous build. There have several who've done so on a stock rebuild without an align hone with excellent results. I guess they all got lucky.
