Solid roller guys only!!!!!!!!
I have a 388 lt1 forged bottom end and using a flat top forged piston built for nitrous. Im also using AFR 210 heads that were also max ported. Lt4 intake and LT headers, bullet, dump. Backed by a th400 trans and a 4.10 gear on 28s.
I will be using a 250 shot minimum and would like to know what the hardcore guys recommend for this setup!
What converter should be used? Im thinking 4000
What cam specs?
anyone with a similar setup to this?
This will be on a stock pcm and im looking to take it all the way to 7000 rpm. SO I need my parts to match, But shifting at 6800 to make it safe
What are your goals for the car? Time expectations? Streetability expectations?
Matt
PSI Endurance Spring 1200 Series
Xcyeledyne Titanium 10* Retainer and Lock
CP Products 3/8" 1 Piece Pushrods
Morel HIPPO Lightweight Solid Roller Lifters
AI Custom Spec'd Solid Roller Billet Core Cam
Jesel 1.6 Shaft Mount Rockers
This setup has proved very very very durable in my car as well as others. I shift at nearly 8000rpm if not higher sometimes and have had great luck so far. Over 170 passes on the motor and 2000 miles of street use. As for your case your going to have to be easy on rpm because of your stock PCM. I read that other thread you posted that went off the deep end sorry to see that bud lol.......honestly in your case espically with tall that spray id look into an aftermarket computer suchh as the FAST XFI....the xfi was some of the best money i've eva spent....tuning is great!!!
The main thing is that I already have the afr210s with the stock solid roller springs good to 750 lift and I have another set that are good to 700 lift. So on springs I should be good. Im looking into getting a shaft mount set that AFR has designed for their head setup. ANyone ever use it or know if it works?
As for the cam I was told to go with 251/259 .664/.664 109 LSA But thats for a 7k rpm shift point and my car wont go that high without problems
In all honesty that combo needs to ditch the stock computer. Then you can get a healthy solid roller, spin it to where it wants to be spun, and let those heads breathe.
Keeping the stock computer will make you have to sacrifice somewhere else...like cam and gearing.
its a 96 but the crank sensor has been deleted to due me running a double roller chain.
How much power can be expected from what my components are?
I ran a few solid roller setups for years.....long before the more cost effective LS1 PCM swap solution. I ran on the stock 95 PCM setup and was limited to 7000rpms. The OBD2 setups are good for 7200rpms as SS RRR mentioned. If I took my car over 7000rpms, the engine would completely shut off right then and there.
I found that my SR engines ran best on an open loop tune. The knock sensor needs to be turned off....at least on my setups it did.
what pushrods to go with, size, brand?
Springs I have are good for 700 lift, so thats handled
Since I have Afr heads, I will just use their stud girdle
Cam I can get from LE himself.
It's hard to swallow the price tag, but go with the ISKY RedZone's or Crower HIPPO (High pressure pin oiling). In the end, they are cheaper than a motor rebuild
As for springs, there are a few different options. I would run the spring that the cam manufacturer recommends. However, I've used the Comp 943 Pacalloy's on all of 3 of the SR motors I've had and they worked great.
Pushrods....this is the last component you will purchase. You need to assemble the engine and measure the exact length. It is VITAL that you have correct valvetrain geometry. This measurement needs to be precise since you don't have the leeway like you do with a hydraulic roller setup.
