solid roller vs HYD roller cams
But hydraulic roller technology has taken some pretty big advances over the past 15 years, and HR valvetrains are spinning higher and higher.
Do a Google search if you need more info.
Better out of the two is down to what engine there going into. one used for racing only or daily driving ? HR lifters are all you should ever really need unless you have an engine spinning to 8k rpm
I know 94Z28Rag's build is still a HR, and that's an AI-headed 396 with a MASSIVE HR cam, still on the stock PCM and opti.
Now if I was regularly pushing 7500+ with a FAST/MoTec/Megasquirt/whatever that would be a different story.
SR also lets you run higher duration and maintain similar tune-ability and drivability then an HR cam. There is a popular trend of running "Street Rollers", fairly modest solid roller cams, in street/strip cars that are often the same or smaller then some of the racier HR grinds.
Unfortunately, my shortblock **** the bed before I got any track times. So I don't have any solid proof of exactly how much quicker it was.
I'm currently building a larger motor now, and sticking with the SR
.From my talks with Llyod it looks like my cam will be one with 260# seat and 600-650# open.
Can't skimp on the valvetrain at all! If you wanna run a decent SR be prepared to spend quite a bit more on lifters, pushrods, and springs then what you are used to with an HR setup.
It will make more power throughout the whole rpm band not just in the upper part of the powerband.
before I pull the trigger on the HR cam although theres guys like Larry aka LS1speed flyin on HR cams. I think Badhawk made like 477rwhp with a HR cam. Tough call since I already have everything but the cam for a HR set up.
Bolo, do you street drive your car ? I DD my car, and now im wondering if mechanical rollers wouldnt be to bad.
