New 255 walbaro fuel pump
My car doesn't rev past 2k without chugging horribly bad like having really bad fuel cut in a turbo car, does the car need to be tuned tp run normal with having this fuel pump? Any help would be greatly appreciated
Your answer was here ^
Also it would have helped if you gave more info on the car, as your sig does show a different vehicle, little things like that help
I am sure you will find your problem by following the advice given above.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
On the end of the pump there should be a filter sock. If it's dirty it might starve the pump of fuel. Also check the hose on top of the pump...make sure its secure on the pump and it doesn't have any kinks or holes in it. Lastly it might be a good idea to check the fuel pressure while driving to see if the pressure drops.
Yea I bought the pump from a friend and it didn't come with a sock so I guess I'll get one for it and try because everytime I clean the pumps mesh filter it runs great then gets clogged again so I'll just buy a sock filter for it thanks for the help
