Stock LT1 crank weight?
looking to spin 8200rpms at max. so i need a very light assembly. 355cithanks, Aaron.
If I were building a high rpm motor, I would start with the lightest pistons and pins that will survive the combination. The stock crank will most likely live N/A, but the crank is a great dollar/HP place to save weight. For the rods I would skip the titanium and buy the lightest forged rods that have 7/16" rod bolts.
Keep in mind that engine components are like anything, you get what you pay for. If you can't afford good stuff change your goals or wait.
As of last night he was in second place for Dragweek smallblock NA so it is holding up fine.
But most guys on post around here, have more money than since.
To do a good LS7 conversion costs a fortune. You are leaving out headers, computer, engine mounts, and a ton of other stuff. Besides, he couldn't run the LTX Shootout if he did that!
really? so crower is a no no?
What kind of oil system are you going to run?
How much do you want to spend on the crankshaft?
Who is going to machine this thing for you?
Are you going to buy front and rear mains?
How often are you going to check the springs?
What kind of driving?
Honestly you need to spend big money on the top end when you want to run in the 8k range. You are going about this build the hard way, I would look to build a lower RPM high TQ motor, this is your first time you dont need a money pit. You aren't going to want to spin a 410ci to 8k, 355-396ci is were you might want to keep it.
High end dirt track motors are easily 20k, once you start putting Ti in a motor the price gets ridiculous. 1200+ for Ti valves at least that for a shaft setup. You are going to have a large shop bill, none of these parts can just be slapped together.
