Origional headlight blew out. What's nice and bright?
So one of my two origional healights blew out on the hawk. What's nice and bright without making it look like a cheap import? Gonna replace both of them cause I'm sure the other one isn't too far behind. Thanx
The House is Rockin'
I like the XtraVisions. My understanding is the filament is the same as silverstar but without the crappy blue coating that makes them bad in foul weather and run hot and burn out.
Halogens do wear out long before failing though so anything is going to be a big improvement.
on camaros you can take the filiment/bulb out of the housings and use a regular bulb i believe 9006/7 in it place just need to silicone them back in....as for lighting at least on my camaro i originally tried the silverstars which are a vast improvement...but since with them being alot cheaper than in 05 when i replaced my bulbs are now running 8000 hid lights which are white bulbs and couldnt be happier
I run the H4 Retrofit housings with a 5,000k hid kit. 100x brighter at night over stock sealed beams and there clear and not blue which look gay. 5,000k is clear so it doesnt look blue and ricer like. IMO i wouldnt waste any money on another sealed beam light. Ive also seen 9007 retrofit housings and they are a cheap upgrade but after driving with HIDs you will not got back.
