vibration under dash
my 95 z28 has a slight vibration just underneath the dash at 2100 rpm and its annoying.replaced u joints,tranny mount, motor mount, and just nw the flywheel and a different torque converter, nothing has fixed it. any suggestions? thanks
It's runs fine, not missing or nothing, but at 2100 rpm it's shakes the change in the console. Not real bad but u can feel it in the transmission panel. U can feel it the most at 70-75 mph
well, just take a look around, if it is pretty minor might just be something rattled loose... F-Body cars arent exactly known for their great ride quality and superb fit and finish... mine rattles and squeeks and thumps... most of which is my own doing but it isn't your grand dad's caddy.
Well I know it has gotten worse. And pretty sure it's at the engine somewhere just don't know where. It ain't the pipes, or anything that rattled loose. U can hear a lil tick sound now in the same area.
or an exhaust leak?
get to checkin around under the car for any rubbing, or anything very close to the underbody... also, my car was notorious for transmission mounts... would start as a thud on accell and eventually end up as a "rattle"
get down with a stethoscope and find it man, obviously you are beyond simple fixes thus far and will probably have to tear into something to find it... pull inspection cover on trans and look for signs?
