Raw furl out exhaust after cam swap?
I finished up my cam swap today (1994 Camaro Cc503 cam) and I just had enough time to start it before work. It fired right up and idled. However I noticed I am getting a significant amount of raw fuel out the exhaust and I'm not sure of this is a characteristic of the cam or not but it seems rough when I rev it. I'm thinking I have a plug wire crossed or an injecter wire crossed. Any other ideas? Thanks guy
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
New 383 combo with lunati voodoo 60122 also spits raw gas; especially when just started cold. I figure I will wait and see what my dyno tuner can do (this one also has PCMforless tune for now). It's only been getting 11 MPG; but that is beating on it in city driving with 4.10 gears...Otherwise, driveability and power are on the money; how does your car drive? Should be a significant power gain from the cam swap...
If you don't have it tuned you shouldn't be running the engine. Dumping that much fuel into the engine is not good. Stop running it.
You have completely altered what the PCM "thinks" it's seeing by changing the valve events and fueling requirements. You can't expect it to run properly until you have it tuned.
Well I ran it around the block just to see and it started backfiring and barely made it home. It ran terrible. I think we are looking at more problems than a bad tune at this point. It stalls and pops and runs like garbage. I checked my plug wires and injectors and they all seem fine. Idk where to go
