Lt1 to ls1 swap
any help and tips would be appreciated.
Complete engine, k member, steering, wiring, ecm, sensors, transmission, transmission cross member, mad wiring skills, tune, and other misc stuff like ac system heater hoses trans cooler freon etc. Etc. Etc
https://ls1tech.com/forums/conversio...-1994-z28.html
As far as the trans crossmember the LS1 one has different mounting points than the LT1 body. I used my LT1 crossmember and extended it and braced it a few inches backwards to accept the mount bolt.
All in all it's a fairly straightforward swap.
And I have to say, it's a thousand times nicer doing anything to a nearly new engine that had a steady engineering foundation than these old stepping stone LT1's.
But seriously, look at how hard it is to get anyone to back any new development of aftermarket stuff. The big cube/aluminum LT1 block is a good example.
Hell, even the LS1/6 stuff is on it's way to the back burner with the new generation.
But take a good hard look at it all, and tell me what market has the most support and choices in what you can throw at it.
I have one of each as well.
win some lose some, most ls guys around here went nitrous. theres even a few dinosaur small block chevy guys running around here too with some toyota AE86s, supras, WRXs and the rest of the gambit. theres always someone faster right around the corner
https://ls1tech.com/forums/conversio...on-sticky.html
He converted and then went with a turbo:
https://ls1tech.com/forums/lt1-lt4-m...going-lq9.html
97badass and myself are in the middle of converting now:
https://ls1tech.com/forums/conversio...dark-side.html
https://ls1tech.com/forums/conversio...-6-0-swap.html
If you want to use a TH400/TH350:
https://ls1tech.com/forums/automatic...questions.html
Some wiring info:
https://ls1tech.com/forums/conversio...rsion-how.html
The LT1's are anything but dead dinosaurs. Is the LS1 a better motor? Yes, in almost every way. Is the LT1 still kicking *** all over the place? Yes. I'm the fastest car in my all-LS1 car club with the only LT1. Real simple NA build.
