what does your 9.5"converter slip?
Just curious what everyone elses converter is slipping on the big end. My vigilante 4000 is right around 9%. As you can see in my sig it gains significantly locking it up.
When you say "big end", what rpm is that? It will "slip" less at higher rpm's.
It will also slip more or less depending on what part of the torque curve you're on at the big end.
My 8" 4200 ATI slips 5 to 6% at 7000 rpm behind my "low torque" 350.
It's a little more hooked up than the similarly-stalled 9.5" converters I've tried.
A Yank SS3600 (9.5") behind my stock engine had less than 2% slip at 5900 rpm.
too friggin much!!! lol....my data logger is picking up a 11% difference between rpm and output shaft speed im now on my 8200rpm rev limiter just as i come through the traps and thats in 2000ft da....the ATI should drop that down to 5-6% like pat said above which should drop me down to 7700-7800 with the 134-135mph trap....if the car picks back up a couple which i hope it will should be mint right around 8000 at 137ish.........i got the car tuned nice this weekend so im ordering the big boy converter today........
The 3000 that was in there was too tight so they loosened it up and its around 3800-4000. This motor will go 7000 but I just don't have the gear. As far as the dyno it lost no power between the old and new.
