HELP!!! oil pump went out
i have a 93 z28 with a lt4 hot cam stock heads ported 1.6 rocker arms 58 mm bbk throttle body k&n intake slp stainless headers no cat borla exhaust shift kit and a 2800 stall i was driving on the free way and i gave a lil gas to get up to speed and when i left off the oil pressure fell to 0 so i hurried up and got off the closes exit towed it back home and the oil pump went out but i dont know what kinda oil pump to buy which is best for my set up thanks guys
Oilpumps are pretty bulletproof, pretty unlikely it is the actual problem.
Find the actual problem. Be it the sending unit, the drive gear, the driveshaft, bearing clearances, those are all more likely than the pump itself.
Did the engine get louder? If it still sounded quiet as it had been I might check it with a mechanical gauge, but if it got loud that verifies lack of flow so do not run it any more.
Before buying parts, try process of elimination you have a 93 remove your oil psi sensor above your oil filter http://shbox.com/1/aux_oil_port.jpg buy a mecanical oil gauge install move gauge up to windshield so its visible, unplug coil wire, check oil level crank over you should read 10-20 psi. If nothing at all your pump can be bad or worst case spun rear main.
He might just be thinking oil slinger because he has 0 PSI and that's the worst thing your car can have (besides being completely wrecked and rolled) and he is trying to think positive about it and blaming it on the oil pump, very assuming of him obviously but we all do it.
I can't remember which one I put in mine. I think it was TRW or something. Lots of guys use Melling. Be sure to check the oil pump drive when you take off the pump. There is a little plastic collar that can break if you try priming the engine with a drill (slight sideways movement can crack them since they get very brittle over time in the engine). There are aftermarket drives with a steel collar, get one of those.
I hope your engine survived okay.
Maybe the oil pickup fell off?
Maybe the oil pump drive broke?
Drian oil is the first place you need to start. This will tell you a lot, is their metallic or not. Then with a flash light and a coat hanger fish for the pick up. If you have a engine camera that would be best.
If the pick up has fallen off and assuming you still have plenty of oil, you will have normal pressure. I am betting the billet LT4 hotcam shredded the oil pump drive gear. I would mallet test the bottom of the pan then pull the intake and then the oil pump drive gear stub.
Update on my car. I called my macantic today to fix it he worked for gm for 30 years. And he wanted to check to oil pump first so we jacked it up and the exhaust got in the way and we couldn't get the bolts off he said we gotta heat them up first then we can drop then pan and see what really happened. Should be done over the weekend I hope
I give you a 98% chance that the problem is the gear and nearly everyone on here would agree with that assuming you have a pan full of oil and it has good pressure at startup.
When I started it there was no pressure at all and I told my macantic about pulling the intake he said lets pull the pan first and just see so I said ok but I wouldn't doubt that the gear went out on it But he still wants to pull the pan for some reason first idk y but we should find the problem tomorrow when he comes back and should be fixed soon. Thanks guys for all the help I'll keep u guys updated on it
