Which gasket to use for stock manifolds?
Ok so from the look of it seems that my exhaust manifold gaskets are blown. Before I start tearing things down, I would like to know all the items I would need to do the job right. What gaskets do I use, do I buy new exhaust manifold bolts and which ones etc..... Any help is appreciated =D!
[QUOTE=SS RRR;16428036]Stock and torque the manifolds bolts from the inside out.[/QUOTE.
I want to make sure I don't have to do the job again so what would be the best safe bet for gasket? Stock gasket or aftermarket? Are stock gaskets metal or cardboard material? How bout the bolts, which ones should I get without having problems? I don't want to use the original ones, they look pretty old to me. Especially when the car is a 93 XD.
Yeah its leaking, plus it makes this annoying *** voice in the morning during startup. I also checked my rocker arms and they are nice and firm! Pretty sure its an exhaust leak. On the pic above me, the exhaust manifold gasket is torn. Stupid CA smog rules that's why and I want to avoid paying big bucks to pay under the table to get it to pass smog if I put headers on. Plus I wouldn't pay 400+ for shorty headers. Will do, is WD-40 good or anything better?
I just sold a set of Edelbrock shorties for $100. The deals are out there if you want to stay legal.
As far as gaskets, just pick up a set of them from the dealer or some FelPros. Either one will work just fine.
Pb blaster, liquid wrench, zep 45 all work good. If you are staying stock get some from the dealer. If the bolts are ok you can just wire wheel them. I would get the bolts at the dealer too, I know they are probably not going to be the cheapest but that is just what I would use. Check the manifolds for cracks too. **** ca smog, how often is the check, once a year?
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
[I want to make sure I don't have to do the job again so what would be the best safe bet for gasket? Stock gasket or aftermarket? Are stock gaskets metal or cardboard material? How bout the bolts, which ones should I get without having problems? I don't want to use the original ones, they look pretty old to me. Especially when the car is a 93 XD.
On a motor with this many heat cycles on it you REALLY REALLY run the risk of snapping the bolts off inside the head. Which is not uncommon, then u will be posting another thread on how to do the teardown and fix...i will be watching for it. Good luck.
