383 Stroker Oil Pan
Old Jul 14, 2012 | 08:12 PM
Z28Camaro30Ann's Avatar
Default 383 Stroker Oil Pan
So I overlooked my oil pan on me new stroker build. Got it all together, got it running, and heard a light tick from the bottom of the motor. Diagnosed it as the crank barely clipping the edges of the oil pan...I forgot to get a pan that was clearanced for a stroker motor.
SO, what pan is the best for this? Moroso, Canton? What else do I need with it? Pickup Tube?
Anyone have these for sale cheap? lol
Old Jul 14, 2012 | 09:42 PM
96capricemgr's Avatar
Your stocker is now marked where you need to tap on it with a hammer...................
Old Jul 14, 2012 | 09:49 PM
noice's Avatar
You can beat a stock pan out easily for 3.75" stroke. I really wouldn't get a Canton, I have one and don't like it at all. However if you do some heavy braking in a stock pan you'll starve the engine of oil if you don't have a accumulator.
Old Jul 14, 2012 | 09:56 PM
fex77k's Avatar
My ******* canton is the worst fitting over priced piece of **** I have ever owned. How do you manage to **** a SBC pan is beyond me.
Old Jul 14, 2012 | 10:42 PM
Puck's Avatar
Quality seems to be very hit-or-miss with the Canton so I can't really recommend it either...Mine fits perfect and clears my 383, but a bunch of people have had issues with it. I don't know if some get warped during welding or what, but its definitely rolling the dice.
To make it worse, there are a couple revisions floating around.
Old Jul 14, 2012 | 11:32 PM
94LTZ's Avatar
My canton is perfect. Just sealed it up again for the turbo build.
Old Jul 15, 2012 | 12:25 AM
fex77k's Avatar
The corners are garbage, had to beat the junk around the rail to use my oil cooler. I have a Stef's on order right now for a drag car, but their customer service has been pretty lukewarm. I had to call three times to get them off their *** to take my money, very little communication on their end.
Old Jul 15, 2012 | 01:42 AM
Hit em Up's Avatar
Well I've heard great things from a few local people about the milodon pan.So I got pn#30909 along with there hd pickup pn#18316 for about $350.Fit was great but can't tell you about seal yet as motor is going on dyno Thursday.Now this pan doesn't have provision for oil level sensor FYI.Fits up to a 4inch stroke.
Old Jul 15, 2012 | 07:47 AM
Mystery Bird's Avatar
Moroso fits perfect on mine, stock oil level sensor fits with Hooker long tubes.
Old Jul 15, 2012 | 08:28 AM
BOLO's Avatar
Take a look at Moroso LT1 oil pan part#20185.
Old Jul 15, 2012 | 09:54 AM
joelster's Avatar
Milodon #30909 will clear a 4" stroke crank, and holds an extra quart of oil. Has a nice deep sump that angles out and still offers good ground clearance. Has a built in windage tray. Fits like a glove too.
http://www.summitracing.com/parts/MIL-30909/
You will probably need a new oil pump pickup to extend that far though. The pan is a little deeper. This one will work:
http://www.summitracing.com/parts/MIL-18701/
Old Jul 15, 2012 | 09:55 AM
joelster's Avatar
That's the pan I run and I have zero issues. Not a single leak. If you need the oil level sensor to tell you to add oil, you're already doing significant damage, lol.
Old Jul 15, 2012 | 01:08 PM
BALLSS's Avatar
as Caprice said you now have what you would have found out if you rotated the motor by hand with the pan on. Typical # 2 rod bolt scraped bottom of pan..but all motors are slightly diffrent
you can buy an aftermarket pan but I run the stock one. I encourage you to run the stock windage tray. use either the 3 extended stock main studs or but the Miloden ones. You simply put 1/8" washers between the stock ones and the tray to space the windage tray for learance if using stock ones
as far as clearanceing the stock pan, for me, I just set the pan on a folded towel on my bench and with the big end of a wood baseball bat "pushed" from the inside where the witness mark was left by, in my case, # 2 rod bolt. Took 2 min at most and a few taps on the end of the bat to push the pan out slightly
Old Jul 15, 2012 | 05:35 PM
warriorcustoms's Avatar
Ive got the Moroso for my 396 build If I remember right its good for 4 1/8th crank Had good luck with em on my 3rd gen long ago So thats what this ones gettin Cantons overpriced **** in my book Milodon is good too
Old Jul 15, 2012 | 07:02 PM
SS RRR's Avatar
Village Troll
Bought my Canton in the mid 2000's and it fit perfectly. If you are planning on using another pan, make sure it will fit with the stock k-member.
Not true.
Old Jul 15, 2012 | 07:21 PM
robsquikz28's Avatar
I have a moroso with oil pump and pick up for sale!!!!! $300 shipped
Old Jul 15, 2012 | 08:14 PM
Well....guess that solves that problem.....thanks Rob, can't wait till it gets here!!!
Old Jul 15, 2012 | 08:19 PM
thank u
Old Jul 15, 2012 | 10:04 PM
Puck's Avatar
Not true.
Mine is from around the same time period.
