N/A HR LTx goes 10.97 at 121.8!
Well I got a 10 sec slip today, went 10.97 at 121.8 on a 1.49 60'. DA was 3500' and the track was pretty decent. In later 1/8 mile runs i gained over 1/2 mph with fueling changes, however the track went away in a retarded fashion. Still have a few .01s in 60' with tightening down the front end, but didn't get a chance while the track was hookin'
Hopefully next time out they can keep the track surface good with some cooler weather!
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Moved TA down one hole in the front to move IC lower. First run was a 1.49 at 12.75 psi cold with a little slip, went 6.97 at 98.1. There was some huge delay and i forgot my portable air compressor and was stuck in the staging lanes. One slick bled off to 10.5psi cold, so i dropped the other to match and ran out the 10.97. I wanted to run at 12.5psi cold! next couple runs 60' dropped to 1.55 and 1.57 with no changes other than correct tire pressure and swapping lanes to try and find a better surface. MPH stayed the same at 98.1 in the 1/8 despite 200' better air over the first pass and fueling corrections. joelster was right on telling me to throw air in the rears, they run alot faster aired up!
