car vibrates at about 75+ mph
If you have 6 speed, drive at 75MPH in 4th and note if the vibe is there. If its vibe free, shift to 5th and note if its there, Then go to sixth and do the same thing.
If you are vibe free in 4th but detect vibes in 5th and 6th gears only, you have T56 wear and tear so go here:
https://ls1tech.com/forums/manual-tr...vibration.html
Something to look into
Best of luck
matt
Replaced springs (lowering kit) - didn't help
Replaced all ball joints -didn't help
Got it aligned and wheels balanced -didn't help
one day I got a power steering leak from the pressure line to the rack. So I had a friend replace the line and the rack...problem solved
Hope you find out what the problem is
