HELP!! Kooks Passenger Side Header will not line up with exhaust
In the process of installing Kooks headers (1 & 3/4X3) on a 97 Lt1 with Kooks catted Y pipe to my Borla. The drivers side header appears to line up with the left rear of the car and Kooks Y pipe, but the passenger side header collector lines up with the center rear of the car. I am thinking it should line up with the right rear. As you can see from the pictures, my Borla to Y pipe is off by about 4 inches. This can not be normal and I didn't pay good money for this.
Has anybody ever ran into this issue before? Thanks.
Is your borla specific made for the lt1? As someone didn't make an LS cat-back fit onto your car. I can't tell from your picture but the Y is suppose to lean/ bend one way more than the other to meet the cat-back.
It's kinda hard to tell, but based on this picture,
, it looks like there may be too much bend in the passenger side of the y-pipe.
http://www.camaroz28.com/forums/exha...y-pipe-588895/
I would call Kooks, or whoever you purchased from, and I suspect they would send you a new y-pipe.
![](http://i238.photobucket.com/albums/ff114/malomanm/ImportedPhotos00002.jpg)
Looks to me to be just another routine header install where fit is never 100% (does not matter even if its a Kooks product) and a little creativity is required to get them on as intended. For a host of reasons, most all cars respond different to a header install.
If in the end the replacement pipe (assuming you get one) does not fit, cut a relief slit in the pipe and then bend it then weld up the slit. You will never bend that pipe without a relief cut. My LPP Y-pipe did that similar thing too.
Kooks thinks the issue may be the Y pipe was made incorrectly. I suspect the header may have an issue with it. Some tweaking on these cars is understood but you should not have to cut and weld for this kind of money. I appreciate your responses and will let you know how it all works out.
Kooks confirmed thru my other pictures which I did not post that the header is the culprit. They are sending me a new one. It did take me pressing the issue and staying persistent for them to admit it. We will see how things go when I get it.
So the passenger side header is screwed up? Why not post your other pictures? I would be interested in seeing them.
Sorry I did not post these earlier. The passenger side header collector is pointed towards the rear end and not more towards the right rear (which I think it should be by an inch or so) New header has arrived but it is hard to tell if it is any different. I'll soon find out. I asked Kooks to also send me another Y pipe but they were sure it was the header. I hope so.
After looking at your latest pictures, particularly 505, I still think it looks like there is a whole lot more bend in the passenger side of the y-pipe compared to the other picture I posted.
Installed new header and the collector pointed towards the right rear at least an inch more than the last header that caused the issue. Kooks Y pipe fits and was able to get everything together. It was just my bad luck that I got a bad passenger side header. Thanks for everybody's input and help.
