Skip 5-6 w/ Pro 5.0 and Adjustable Springs
Finally pulled the trigger on putting a shifter in my '97 WS6, went ahead and bought the Pro 5.0 on sale and picked up a Skip5-6.
The Skip5-6 is a nifty little device that locks out the 5-6 and Reverse gates on the shifter until you need those gears. It makes the T-56 work exactly like a 4-speed. WOO-HOO! No chance of ever missing 3rd again!
I also modified my Pro-5.0 to have adjustable spring pressure from the 1-2 gate back to center. This was to avoid the common practice of having to shim the shifter a zillion times to get the feel right.
![](http://i1249.photobucket.com/albums/hh502/dcoler/Pro%205%20and%20Skip5-6/IMAG2539_zps6f76290f.jpg)
![](http://i1249.photobucket.com/albums/hh502/dcoler/Pro%205%20and%20Skip5-6/IMAG2540_zps1e63ba74.jpg)
Built the aluminum bracket for the set screw to adjust spring pressure
![](http://i1249.photobucket.com/albums/hh502/dcoler/Pro%205%20and%20Skip5-6/IMAG2544_zps45d01b12.jpg)
![](http://i1249.photobucket.com/albums/hh502/dcoler/Pro%205%20and%20Skip5-6/IMAG2550_zpsb4037c9e.jpg)
You can see the post that drops down between the shifter and the spring retainer plate. This physically locks out the farthest two gates to the right.
![](http://i1249.photobucket.com/albums/hh502/dcoler/Pro%205%20and%20Skip5-6/IMAG2551_zpsaa7cb881.jpg)
![](http://i1249.photobucket.com/albums/hh502/dcoler/Pro%205%20and%20Skip5-6/IMAG2552_zpsdec890e4.jpg)
![](http://i1249.photobucket.com/albums/hh502/dcoler/Pro%205%20and%20Skip5-6/IMG_7612_zps96f33450.jpg)
![](http://i1249.photobucket.com/albums/hh502/dcoler/Pro%205%20and%20Skip5-6/IMAG2549_zps841efeb2.jpg)
![](http://i1249.photobucket.com/albums/hh502/dcoler/Pro%205%20and%20Skip5-6/IMG_7613_zpsf962f640.jpg)
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Do you have a link to more information about that "Skip 5-6"?
Where did you buy it from? Cost?
And, how is it activated, (i.e. how do you get that pin/post to "drop down" and lock out 5-6 & reverse)? Twist the ring, or pull/push it? Also what locks that pin in position when it is activated?
Skip5-6 has a website (http://skip5-6.com/) with a video demonstration.
Its absolutely awesome BTW.
Pushing the ring down locks out 5-6, it cost $79 for the Pro 5.0 model and $64 for the B&M model and I bought it from Ebay.
looks awesome a lot of work into a shifter, fortunetley i've gotte very good at 2-3 shifts, although sometimes when out of practice i tend to mess up my 3-4 shifts for 3-2 shifts.... ouch. haha
Just out of curiosity, has anyone else used the Skip5-6? I looked around before I bought mine but only found other people asking the same question.
