Vortech V1 T-Trim install
Hey guys, the other forums are boring so I wanted to post here my vortech install.
I picked up a used vortech V1 kit for a pretty good price, its missing a few things but notthing major. only after I got the kit did I realize i need a custom AC line made so thats about the worst part, other then that I need a belt and air filter.
Im doing a LT4 hot cam install at the same time along with a EWP.
You can see in the last picture why I need the AC line.. unless I can figure out some other way to run the intake tubing.
I am planning to install the complete Lt4 hot cam kit, Do you think ill have valve float with boost at 6 or 7 lbs?
Still need to order injectors and maybe a fuel pump. I really want to get it running by the weekend but I dont know how thats going to go.. cam won't be here untill Thursday.
Why the hotcam?
Yes, valve float will occur on the hotcam kit valve springs under boost.
You can always try and relocate your drier first before making a whole new line.
Don't forget a good set of headers. I see you still have the stock manifolds on the car..
Headers are coming.
I did the hot cam because it was $100, I know its not idea under boost. this is not a max effort build. Street car that sounds good and has some giddy up.
They are supposed to last about 5-10K miles depending on use and cam selection. No direct experience here though. I have Howards Cam Springs and supposedly they are in the same boat as Alex Springs.
Not sure how they'd do with boost.
Hotcam springs barely have enough seat pressure to control heavy LT1 valves NA. Adding boost to that will be a disaster. A blower will fight the intake valve spring allowing it to float.
You need more than just tougher springs. Hardened pushrods, NSA rockers, guideplates, studs, possibly lifters, etc. Everything in the valvetrain will be under more stress with stiff springs and relatively aggressive aftermarket lobes. Even the timing set could be affected.
The Hotcam is okay for boost with the duration split and the overlap at -1 (not ideal but pretty good). There are definitely better shelf cams out there. The cc305 is a tiny bit better but only because there's more duration and lift (overlap @ -3 which is in the wrong direction for a blower). If you want more zing without going overboard then I'd go with the 224/236. Don't remember the specs exactly, but I know the overlap is a few degrees positive and there's more lift on the exhaust side where it really counts.
Another vote to ditch the hotcam and go with the 224/236. Specs on it are 224/236 .536/.555 lift. 114 lsa. It's a known quantity and makes a ton of useable power and torque under the curve. Drives and sounds just as well as the hotcam too.
I already bought the hotcam - I didnt really intend to do a cam, but wanted to go ahead with something cheap since I had to take the timing cover off anyways for the EWP.
Later down the line when I want more power I would replace the cam with a LE cam and a forged bottom end but for now im gona run this setup.
What does the alignment look like without the silicone coupler on there? If that is keeping the elbow out a bit because it is pushing on the IAT bung, maybe a narrower one would let the elbow get closer to the throttle body. Obviously, if they are already metal to metal, then that isn't the case.
As for your oil drain - mine is the same way and if you put on the bracket before the hose clamp, then it is practically impossible to get the hose clamp on. You might be able extend the drain though with a longer pipe nipple, then go from there.
The problem is how the EWP housing is much larger then factory so its sticking out. Right now i need to finish mounting the blower up and ill address it further. I ended up taking the blower apart and am reinstalling it as per vortechs instructions instead of blowerworks, so I can get a proper clamp on the drain.
I got my Alex's valve springs today, having fun installing those..Hopefully I can start it Friday night or Saturday morning.
I'd need a photo from the front to be certain it's possible, but judging from the photos posted, I'd try to re-clock the supercharger's exducer housing (counter-clockwise) to get its outlet away from the EWP. If you can't route the ductwork next to it, then route it over it.
