Compatible OB2 LT1 PCM's
Old Apr 17, 2017 | 09:31 AM
CamOnlyJabroni's Avatar
Default Compatible OB2 LT1 PCM's
So I bought the JET tuning software to convert my car to speed density and it bricked my PCM. I guess some people have problems with the cable they send with the program. I am in the process of getting a different style cable and a new pcm. Does anyone know what model and years of cars have the pcm as a 96-97 trans am and camaro z28? I found a pcm out of a 96' caprice but don't know if it will work or not.
Thanks.
Old Apr 17, 2017 | 11:25 AM
KW Baraka's Avatar
Originally Posted by CamOnlyJabroni
So I bought the JET tuning software to convert my car to speed density and it bricked my PCM.....
You messed when you bought a JET electronics product. Those things are so notoriously bad!
Anyway......1996 Impala SS, Caprice, Roadmaster, Caddy Fleetwood, and 1996/97 Corvette will all have the OBD-2 still PCM that you want.
Should be pretty easy to score one on the Impala SS forum.
Happy hunting!
KW
Old Apr 17, 2017 | 12:42 PM
Dirty_Bird's Avatar
What can you use besides jet to tune obd2s? My buddy has jet also and it loves to brick pcms
Old Apr 17, 2017 | 01:12 PM
ACE1252's Avatar
I've been using JetDST for years have not bricked one PCM.
Are they still selling the OBD2 kit with a module that has a 9 pin DB connector to go to computer?
If so, what kind of laptop are you using? If it doesn't have a built in hardware 9 pin DB connector on the motherboard you are asking for trouble as 9 pin DB to USB adapters can jack up the communications.
I think there are some USB adapters that can work, but you have to get one with a specific chipset in it. I can't speak as to which one to buy as I use a laptop with a hardware com port....simply not going to chance it.
Old Apr 17, 2017 | 01:37 PM
merim123's Avatar
i have a complete lt1 obd2 setup with LT1 edit for it tied to PCM. My PCM also has the lt4 knock sensor in it and it's been socketed. You can buy my complete setup with a dyno tune on it. or...
if you want to keep it cheaper...send your pcm out and get it socketed by Andy at akm cables. he did my setup and no issues or need to replace the PCM.
Old Apr 17, 2017 | 01:58 PM
stevo9389's Avatar
The FTDI chipsets I believe are what you are looking for in the RS232 -> USB converters. There's also a DIY solution here.
What seems to happen to most people I know is the computer/lap top may go to screen saver or other background programs interfering. A few times there were too many accessories (including dome light) active in the car while the PCM is being erased and re-flashed. It sounds dumb but most don't realize that the PCM is not always seeing the same battery voltage that you measure at the terminals so bad grounds or other wiring issues that come with age can play a big factor in the success/failure.
Old Apr 17, 2017 | 03:30 PM
myltwon's Avatar
Now who would you know that might've had that happen
Old Apr 17, 2017 | 04:02 PM
stevo9389's Avatar
HAHA! You, GMRACER, Plan_Z, Launch, Davis, myself.
EDIT: maybe not GMRACER but he was there for at least one of those events.
Old Apr 18, 2017 | 07:04 AM
moehorsepower's Avatar
If you are talking about Andrew @ AKM, he quit doing that years ago..
Old Apr 18, 2017 | 08:06 AM
merim123's Avatar
lol. tells you how old i am. I had him do it circa 2010-2011 if I recall.
Old Apr 18, 2017 | 06:20 PM
Camaro_freak's Avatar
I bought Jet DST when it first came out and have re-flashed at least 100 times with no bricks. Using an old XP laptop with native rs-232 port and all screen savers and sleep mode disabled.
Old Apr 19, 2017 | 01:49 AM
madhatter's Avatar
My shop contracted out to a guy to come in and flash whenever we had new body/feature modules or PCMs installed. He always had us install a battery charger on the vehicle before he started flashing it. He easily did over 100 vehicles for me without issue.
Old Apr 19, 2017 | 07:49 AM
Thanks for all the replies guys. I am using a older Toshiba laptop with Windows 7. I have used TunerCats from Solomon when he tuned my car and had zero problems. I also read on the webz people have had problems with Jet when using a USB type b to usb cable. That's what their tuning software comes with now, but there isn't a 9 pin like the how the TunerCats is on the diagnostic plug side of the converter box. The tuning went fine until I went to flash a new tune. Crashed right when it opened the pcm. Downloading the original backup was a breeze.
My laptop does NOT have a 9 pin port.
