Torqhead and 1997 Camaro SS Air Intake
I am on the fence about ordering the Torqhead kit for my 97 SS. My concern is if the stock air intake will fit if the coilpacks are located on the valve covers. Has anyone installed this kit on a LT1 f body SS? I do not really want to relocate the coilpacks of I do not have to.
Village Troll
Keep the SS intake, but take it off the engine. It's doing you no good. Replace it with aftermarket CAI into the fender. There is no spot that is more dead for airflow than in the center of the hood which means there is no "ram air" effect. CAI is far better.
Just curious, has this ever been proven or just an assumption? Is a CAI a worthwhile upgrade for an SS?
Village Troll
Proven. The highest points of pressure on a hood are in the front and the cowl area. That's why you see a lot of race cars with cowl induction hoods. The SLP Firehawks with their induction in the front of the hood was true ram air. Basic f-bodys that had 3" cat back exhaust and CAI were pulling the same mid-to-high 13 second 1/4 times the SS was pulling back in the day. The extra power of the SS over the Z28 was in the catback and not ram air. Wasn't any real way to do a dyno comparison since there was no way to simulate the air pressure at high speeds. The other convenient thing about getting rid of the ram air (at least if working on the engine) is you don't have to remove it every time you want to do something to the engine.
LT-1 Front Cover with Crank Sensor
Hi RB, I too have the IGN-8/ECU-882C AND this uses a Crankshaft Target Wheel that REPLACES The GM Four Tooth with a 24 Tooth Reluctor. ( My Product)
I have the GEN-IV coils that MANY mount in the Frame Rail/Oil Pan Area, a "clean" look. (hidden)
Will you be EFI or Carb ?
Lance, BTW my kit costs less
