Compression Ratio
Old Mar 23, 2005 | 09:49 AM
BOTTLEDZ's Avatar
Default Compression Ratio
Quick question i don't need an exact #, but if you were running a 10.5.1 compression ration on a 64cc head what would it be on a 58cc? I have seen the formula that some one posted up on here, but unfortunally i suck at math and don't have all the exact # like gasket thicknes nor deck hight
any help would be appreciated.
thanks
Old Mar 23, 2005 | 11:14 AM
96SCTA's Avatar
higher than 10.5.1 !!!
lol
sorry bro i dont know how to figure out the math on that. And i just had it explained to me yesterday. I should have payed more attention.
Old Mar 23, 2005 | 11:33 AM
BOTTLEDZ's Avatar
True. Anyone else?
Old Mar 23, 2005 | 05:44 PM
Kevin Hall's Avatar
https://ls1tech.com/forums/lt1-lt4-modifications/261815-calculating-compression-ratio.html
Come one guys....it's a sticky!!
Old Mar 23, 2005 | 06:10 PM
METALBEAST's Avatar
Not knowing your other specs, I had to mess with the formula I posted in the sticky a little. Assuming everything else stays the same and your original CR was 10.5/1. Switching to a 58cc head would yield an 11.25/1 CR.
Remember though! Your stock heads are 58cc NOT 64cc.
Old Mar 24, 2005 | 04:41 PM
BOTTLEDZ's Avatar
RIGHT but i'm changing the compression on the pistons the JE pistons i ordered with my set up show only as a 10.5.1 on a 64 cc head only and i have a 58cc head so i was just wondering when its all said and done i'm expecting to end up no more than 11.5.1.
Old Mar 24, 2005 | 07:59 PM
regorih383's Avatar
it woud be 11:1:0
Old Mar 24, 2005 | 11:22 PM
METALBEAST's Avatar
Right. Therefore your new CR is 11.25/1 with the 58 cc heads.
