LT1 Dyno Archive
A4 4300 TCS converter, 9 inch 4.11 gears, 325/50 drag radials
383 LT1 12.66 comp, pump gas
solid roller 254/254@.050
rhs 235 heads
super vic
sheetmetal elbow, monoblade
1 7/8 headers, 3.5 inch y pipe, 4 inch mufflex, magnaflow muffler
Numbers through full exhaust with pump fuel and two wounded pistons(I found them later and am fixing them now)
593 RWT
Numbers are before the tune, and before the proper injectors and new trans were in (the old one was slipping) and before the new throttle body went it.
12 bolt rear,3.73 gear,17in C5 rims, 275 BFG TA Drags, 462 lift long duration cam, new lifters rockers pushrods, CAI, BBK Short tube headers, Muffler delete, Polished throttle body, 32lb injectors, New spark plugs, 3 1/2in aluminum driveshaft, vigilante torque converter, new trans with shift kit (out of 96 automatic) Procharger at 9psi---other small mods
1995 Z28,M6, 22k miles, stock 10 bolt
Pacesetter LT's/OR/Y
Hooker 3'' cat back
Aluminum Driveshaft
Leigenfelter CIA
PCM for less dyno tune
Control arms/relocation brackets/ eibach springs/ bilstiens
Free mods
306whp & 338wtq. Car went 13.2@107 on a slipping clutch and M.T. d/r's. Fried #5 plug wire.
Installed new clutch and lighter flywheel= 13.06 @ 108. We're going to pull the front sway bar and install 1.7 r.r.'s and shoot for 12's.
Hooker 3'' cat back
Aluminum Driveshaft
Leigenfelter CIA
Free mods
On another note, I don't doubt the HP numbers. My car last made 296/323 at the rear wheels before I put a cam in it. That was also with the stock exhaust manifolds as well. They're out there.
I have no clue what kind of power i have or what i will run i havent had it at the track.
Made it on a Dynojet, I can get the sheets to prove it. Brian from PCM for Less tuned the car.
That would make the car more mean than with stock rockers...
Not a huge hot cam fan, but with rockers there not bad
288hp/328tq cut out open
This was dynoed with moser 9" and 17x11 zr1's with bfg 315's, now it has staock rear back in it and lighter rims and tires.
Completely stock motor with moroso intake, pacesetter lt's with offroad y-pipe, no-flowmaster exhaust (now has self made center exhaust), cut out, tb bypass, ait relocation, msd wires, 6 speed, no computer tune.
got a 12.5 afr at low rpm and saw 14.1 to the top, I need to add a converter and because the exhaust only has a bullet muffler and it is way to free flowing for stock motor, and a computer tune.
I was told I probably gain back 10 hp or so by putting the stock rear back in and getting rid of the heavy 17x11's.
Steve
Oh yea, and I ran 13.56 at 102.3mph and on the next run all my numbers were 3 tenths faster up to 1000 ft mark when I snapped the driveshaft and coasted over at 14.5 and still beat the mustang 4.6 gt I was running, lol.
im guessing after the long tubes i will be right around 300-330 RWHP range and hopefully with the LT's, torsen, and brakets ill be in the 13.0 to 13.1 range. been thinking about just juicing it and hoping for 11.9.
Where do you all think i am at in reference to RWHP #'s
Ported heads
Ported Intake
30 cc dished Diamond Pistons
Forged Eagle Internals
Comp Cams 224 / 224 .528/.499 115
The Dyno Shop tune
Racetronix Walbro 255 fuel pump
42lbs Injectors
STS turbo T04E 60-1 @ 8.5psi
Dyno Results
Horsepower: 462
Torque: 440
rhs 235 heads
super vic
