aftermarket optispark
i am looking for the web page r phone # for the company that has upgraded the opti. i think the co is located in ill r indiana. any info is helpfull, thanks . <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Re: aftermarket optispark
Are you referring to the dynaspark?
If so, go here
http://www.dynotech-eng.com/dynaspark.htm
keep in mind this thing is not cheap at $575 or so bux. It's gauranteed for about 1 year I believe. I went with the LTCC which doesn't require you to take off your stock opti. The LTCC unit information is here;
http://www.geocities.com/reilym/LTCC/
If so, go here
My problem with the LTCC is that it still needs a good opti to get the pulse info.
My opti is throwing both hi-res and lo-res faults right now. An LTCC wouldn't do diddly in that case, I need a new opti anyway.
My '94Z's been down since Feb awaiting Phil's early style Opti. Now I see on his site it's mid April. Damn, I'm missing convertible season waiting for that thing, and I don't really want to switch to the dowel-style opti unit. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> If I do that, might as well change cams, as I'd have to drop the oil pan, pull & replace the timing cover, etc.
Ah well. Chevy. "Like a Rock". It don't move.
-Andrew
-Andrew
don't feel like the lone ranger. the last time i heard mine run was after an 11.31 at 121 and on the day earnheart's death. so that's 2 years. my dist will be here next week. and then to the dyno and maybe some 600hp pulls. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
no my mains let go and have been building 396 12to1 with afr heads and such. plan to make 600plus. just waiting on the dist to dyno. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mightyquickz28:
<strong> Camaroholic- have you pulled your opti off and tried to clean the optical sensor? Usually, it's just debris like rust flakes, etc that obscure the *eye* of the sensor or the light source. It would be worth it to clean it I would think. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm the type to do it once. I ordered the Dynaspark last week (the '95-97 version). That does mean I have to replace the timing cover & cam dowel.
The XE-230/236 from Thunder Racing with the longer dowel is now sitting on the shelf in my office. <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" /> (gotta replace the dowel anyway, right? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> )
Just awaiting the Dynaspark. Got everything else needed for the cam swap & opti install.
-Andrew
-Andrew
i converted my 94 before it let go. and i am waiting for my dist also. then i get my cust made e-lbow and to the dyno. i am tring to get this together for bowling green to kick some ls-1 but. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
