View Poll Results: LT1 LS1 LID CONVERSION???
Yes As Soon As They Started Selling
36
35.64%
No Not Interested
21
20.79%
Maybe Depending on price
45
44.55%
Multiple Choice Poll. Voters: 101. You may not vote on this poll
LT1 LS1 Airlid Conversion
Old Jan 18, 2007 | 09:04 AM
  #61
the_merv's Avatar
Veteran: Air Force
Actually, I got it to work. You might of seen it in the other thread.
Old Jan 18, 2007 | 01:40 PM
  #62
TAEnvy's Avatar
Looks good merv hurry up and get that bad boy to the track.
Old Jan 18, 2007 | 01:42 PM
  #63
the_merv's Avatar
Veteran: Air Force
Dude.. you ain't lyin. I am tryin to get info on when Memphis opens up. It threw down some good numbers on the Dyno, well atleast the ones that are accurate.
Old Jan 18, 2007 | 09:00 PM
  #64
InsaneAuto86's Avatar
http://i103.photobucket.com/albums/m...erv/ENGINE.jpg
http://i103.photobucket.com/albums/m...rv/ENGINE5.jpg
>>>NO NEED TO QUOTE PICS!!!<<<
Merv, looks like you got rid of that black box when you deleted your a/c. By any chance do you want to PM me and let me in on how you did it? Thanks!
Old Jan 18, 2007 | 09:01 PM
  #65
Originally Posted by borninatransam
for all those who say 25hp is possible. youre wrong. no **** youre not gonna see 25hp difference with a stock motor. just like youre not going to see 10hp difference with a cai. but if you have a heavily modded motor(h/c/i cars with larger throttle bodies) you can definitely expect to see a difference from cai to lid. i would do it minus the stock lid. i would want to purchase an aftermarket lid.
Thats funny b/c when I got my K&N FIPK it came with a dyno sheet proving it adds 18rwhp to a stock LT1.
Old Jan 18, 2007 | 09:12 PM
  #66
the_merv's Avatar
Veteran: Air Force
I tell you guys right now, this is a hell of alot of gain over the old CAI that I had in this Car..
This thing moves in the top end, 3rd at 75mph will throw you into the seat, and all I have is the little LT4 Hotcam.
Old Jan 18, 2007 | 09:15 PM
  #67
the_merv's Avatar
Veteran: Air Force
You like that..there's all kinds of room there..
I just took out the Dremel and cut the Face of the Box off until it was flush with the Fire Wall. I did that so I could keep my Heat intact since the Heater Core is inside of the Car. Then I cut a piece out of the way on the inside so the Blower Motor can still blow into the Core and get me Heat. After all that was done, I cut-fit and bolted an Aluminum Panel on the Fire Wall. It was easy, and a hell of alot more convienent with the AC gone.
Old Jan 19, 2007 | 09:23 AM
  #68
always faster's Avatar
Do you got some pics of the actual job,like a write up?
Like maybe a before/throughout/after...It would be nice since i ve delet my a/c but still got the box.
Old Jan 19, 2007 | 02:31 PM
  #69
NotACop97Z's Avatar
! sugestion to what the Merve did, where he used sheet metal to make a path for the blower to flow through the heater corp I used fiberglass.
Old Jan 19, 2007 | 03:59 PM
  #70
Lethal Z's Avatar
Well Im in the same boat, I too would like to know whats involved in the box removal.
Old Jan 19, 2007 | 05:41 PM
  #71
the_merv's Avatar
Veteran: Air Force
I had a thread a while back of it, it's a hell of alot easier with no Engine in there..
You have to cut a piece of plastic out of the center of the box when you cut the face of it off so the Blower Motor will still hit the Heater Core. It works fine, I have all kinds of room in there, and still have heat.
Old Jan 19, 2007 | 07:50 PM
  #72
NotACop97Z's Avatar
Old Jan 20, 2007 | 08:22 AM
  #73
Thank you Merv!!! I think I'll have to wait till my engine is out to do that one! But the heat still works fine?
Old Jan 20, 2007 | 10:45 AM
  #74
Is everyone using the 98-99 or 00-02 style air lid to do the LS1 intake conversion? What is the difference?
Old Jan 20, 2007 | 04:20 PM
  #75
the_merv's Avatar
Veteran: Air Force
Yea, I got heat. It doesn't blow as strong as it did cause the Air paths in there changed, but it still works. That **** is something you keep..
Old Jan 20, 2007 | 06:45 PM
  #76
93_z28's Avatar
i took out the heater core to and then got an electric heater just to use as a defroster.it workes pretty good and even warms up my car a little
Old Jan 20, 2007 | 07:59 PM
  #77
NotACop97Z's Avatar
Merve is your sheet metal leaking, did you just RTV the gaps?
Old Jan 20, 2007 | 08:04 PM
  #78
the_merv's Avatar
Veteran: Air Force
I bet it does in some spots, but not enough for me to have found it yet. I got some rubber on the spots where it's flush to seal it. The metal is cut pretty tight on it too.
Old Jan 20, 2007 | 10:09 PM
  #79
speed_demon24's Avatar
I love how people keep hacking up their cars to do this mod when there hasn't been 1 before/after dyno posted yet.
Old Jan 20, 2007 | 10:20 PM
  #80
hyperzone's Avatar
- would be alot easier to change/clean the filter than my CAI.
- Would make a little more room in the engine bay
- Hard to believe it offers NO GAIN over a stock or typical CAI. (some people will nickle and dime every hp they can get. 5 here, 2 here, 10 here, 4 here.... starts adding up.)
I would prefer to just get a hood that would fit a stock LS1 shroud in there so I wouldn't have to cut up the metal in front of the radiator.
