View Poll Results: LT1 LS1 LID CONVERSION???
Yes As Soon As They Started Selling
36
35.64%
No Not Interested
21
20.79%
Maybe Depending on price
45
44.55%
Multiple Choice Poll. Voters: 101. You may not vote on this poll
LT1 LS1 Airlid Conversion
Old Apr 7, 2007 | 06:49 PM
  #101
1SLO6's Avatar
to be honest lets stop F#$(IN bench racing and get it done.... it may pick up some power, but if u are a modified car dont think it will be a huge difference....i want to get into the technical end of it but i am just to lazy....in my own knowledge and opinion more air flow better power... less turbulence more power. if u go from a long CAI tube like on the LT1 to a LS1 lid style all u are doing is shorten the air flow allowing the engine to breath easier the only problem is that u might pick up some hot air from the engine....maybe.....the only intake i would ever change to is the K/N FIPK with open air filter element that might make some difference.
Old Apr 9, 2007 | 02:59 PM
  #102
camarolvr69's Avatar
Merv, would this intake work with a harwood 2.5 inch cowl induction hood?
Old Apr 15, 2007 | 03:28 PM
  #103
Mike96z's Avatar
Ive done it to my car, my avatar <-------
Old Apr 15, 2007 | 03:57 PM
  #104
DaveH71's Avatar
im really intrested in doing this to my 94 z but i dont really know how to
Old Apr 15, 2007 | 04:18 PM
  #105
the_merv's Avatar
Veteran: Air Force
I did it under a stock Hood, some people have set it up under that Hood I believe.
Old Apr 15, 2007 | 05:08 PM
  #106
Mike96z's Avatar
The way I did it, get the following parts:
3.8L Intake bellow or Supercharger one (so you can connect circle to oval)
LS1 Radiator Support $20-30
LS1 Lid (Aftermarket is best, say SLP)
There are various ways to make it work, and the IAT sensor will be relocated rite in front of the Throttle body, and just make a hole for the opti vacuum.
Old Apr 15, 2007 | 06:00 PM
  #107
94Z28Joe's Avatar
How do you get the ls1 upper and lower air box to fit under a stock hood?
Old Apr 15, 2007 | 06:32 PM
  #108
the_merv's Avatar
Veteran: Air Force
You don't, this is how I did it..
http://i103.photobucket.com/albums/m...erv/ENGINE.jpg
http://i103.photobucket.com/albums/m...rv/ENGINE5.jpg
NO NEED TO POST THE SAME PICS TWO TIMES!!!
Soon there is goin to be a 402ci LS2 in there..
Old Apr 15, 2007 | 06:43 PM
  #109
thebufenator's Avatar
so does buying the ls1 radiator support get rid of the fab work that merv had to do?
Old Apr 15, 2007 | 06:45 PM
  #110
the_merv's Avatar
Veteran: Air Force
No, cause it won't fit under the Stock Hood, on a Camaro anyways..
Old Apr 18, 2007 | 09:32 AM
  #111
hmmmm, I dont suppose on Ultra Z hood would make it fit?
I guess I can cut the hood underneath.......what tools did you use?
Old Apr 18, 2007 | 10:02 AM
  #112
the_merv's Avatar
Veteran: Air Force
6 pack and a Dremel..
Old Apr 18, 2007 | 10:46 AM
  #113
alright, ls1 radiator mount + 6 pack + dremel + cut the hood right?
Any cutting required on the frame if i use the radiator mount?
Old Apr 18, 2007 | 10:53 AM
  #114
the_merv's Avatar
Veteran: Air Force
What kind of car do you have..
Old Apr 18, 2007 | 11:11 AM
  #115
93 Z28
needs a new paint job
Old Apr 18, 2007 | 12:10 PM
  #116
the_merv's Avatar
Veteran: Air Force
It won't fit under the Hood bro, not with the LS1 Radiator Shroud on it.
Old Apr 18, 2007 | 12:36 PM
  #117
rats.
So I have to fab it up to fit, or use the ls1 shroud and a cowl hood
Old Apr 18, 2007 | 12:45 PM
  #118
the_merv's Avatar
Veteran: Air Force
That's a close fit in itself..
Old Jul 16, 2007 | 11:35 PM
  #119
346Vette's Avatar
Good god, whats wrong with a LT1 CAI? I hate lids!
Old Jul 17, 2007 | 08:59 PM
  #120
FASTFATBOY's Avatar
Unless you sheilded it somehow, that setup is pulling hot air right off the radiator/condenser. The only way that would work is with a lower box and a Fast Times ram air type deal under it.
Just my .o2
David
