LT install
Old Apr 9, 2007 | 01:20 AM
Revelation Z28's Avatar
Default LT install
im planning on doing the install in 1 day-2 days. im not gonna un mount the engine because ive heard its time consuming. what is there to look for?
oh yea, i have 3 broken bolts on the driver's side broken at the head so im gonna have to EZ out them.
Old Apr 9, 2007 | 01:25 AM
LT1MAN's Avatar
its all going to be time consuming, no way around it.
Old Apr 9, 2007 | 01:26 AM
well i just dont want to unmount the engine.
Old Apr 9, 2007 | 01:48 AM
b00ya4u2's Avatar
when i did my pacesetters there was no need to unmount the motor, they went up without much problems. Driver side was easy with the steering shaft outta the way. Passanger side the car has to be up real high to get em in but it goes.
Old Apr 9, 2007 | 02:08 AM
im gonna have the car on rhino ramps so itll be up a good 16-18".
Old Apr 9, 2007 | 02:12 AM
b00ya4u2's Avatar
for passanger sides its gonna be up higher then that. The header has to go in almost straight up. I've seen people take old wheels and stack them 2 high and put the car on them then put the header in. I did mine not very safe but effective lol. I had to put 4 pieces of 2x4 screwed together on the jack and lift the car up with that.
Old Apr 9, 2007 | 02:17 AM
oh so put it on the ramps then use wood on a jack to lift the front of the K member.
Old Apr 9, 2007 | 02:21 AM
b00ya4u2's Avatar
thats what i had to do. I dont suggest it unless u have Subframes u can put big jackstands under just in case. I did it very quickly, lifted put the header in had a friend hold it up and lowered the car back down to a safe height. My back bumper was almost on the ground thats how high the front had to be.
Old Apr 9, 2007 | 02:37 AM
ill figure out how to do it once im out there.
Old Apr 9, 2007 | 03:09 AM
siniSSter's Avatar
+1 the tires on all the cars I've done are at chest level to get them in. Good luck on the install, you'll get it, just make sure the car is real high....Trust us....
Old Apr 9, 2007 | 04:44 AM
3pnt4maro's Avatar
mine went in from the top with no problems..whats the fuss??
oh yeah my motor was already out and then we dropped the motor in..i knew i forgot something
Old Apr 9, 2007 | 06:31 AM
moserman's Avatar
if you have that car up only 16-18 inches, it aint comin out cuz you arent gonna get the car high enough to get the motor out...... take it out from the top.... i did a full LT1 swap from the top with the intake, crank pulley and waterpump on and it wasnt bad at all
Old Apr 9, 2007 | 08:52 AM
METALBEAST's Avatar
Take the motor mounts loose. Its not hard. Jack the engine up and they should slide right in as long as the car is high enough.
Old Apr 9, 2007 | 09:50 AM
well ill try and get the front end as high as i can.
i can fit into tight areas so thats a plus.
i dont want to bother with jacking the engine. i want to get the old manifolds off quick because the drilling is gonna be a bitch.
im gonna be using air tools so thatll help me too.
Old Apr 9, 2007 | 02:34 PM
3pnt4maro's Avatar
same here alot easier than everyone says
Old Apr 9, 2007 | 09:18 PM
im not dropping the motor... where did that come from?
Old Apr 9, 2007 | 09:57 PM
97Formy's Avatar
I installed mine from the top. Removed the pass valve cover, raised the motor and it slid right in. It was alot easier then I thought it would be. Hell the install is the easy part. Getting all the old stuff off is the crappy part of the job.
Old Apr 9, 2007 | 10:03 PM
worst part for me is the broken bolts i have to get out.
Old Apr 9, 2007 | 10:14 PM
97Formy's Avatar
Thats true..... I stand corrected. That part of the job is gonna suck worse than any other part. I hope it comes together for you as easily as possible. Just remember that when there finally in you will love them. Trust me
Old Apr 10, 2007 | 10:04 AM
LT1MAN's Avatar
same here, they dropped the whole car down on my cradle, easiest long tube install ever!
(and no thats not me in the picture)
