Where is the schraeder valve on the fuel rail located on my 93 LT1?
I was trying to hook up a wet kit to my 93 LT1 TA but i couldn't find a way to get gas to the fuel solenoid. So right now im stumped, on my LS1 its just right there at the end of the fuel rail but im lost on this car... Ive searched google all over but they just show pics of it installed
. Can someone help me get fuel to the solenoid ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks
B.J.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Thanks
B.J.
Originally Posted by Tony Shepherd
That is a 94+ fuel rail in that pic. If that is the case...it is in the very back of the intake at the top.
On my '94 it is on the back of the fuel rail.
![](http://i145.photobucket.com/albums/r229/jblazina/P1010049.jpg)
I used a 90* Swivel with a 1' long -4AN line to a y-block. From the y-block I'm running it to the fuel solenoid and a fuel pressure sending unit.
All you have to do is get a valve stem puller and you take the dust cap off, and then unscrew the center of the shrader valve. Then make sure you screw the elbow onto the fuel rail well. BE EXTREMELY CAREFUL when mounting it to the fuel rail, the way it is attached, the connection is extremely fragile. With -AN fittings you don't have to tighten it down too much anyways.
