Mono Blade TB's
Old Jul 31, 2007 | 05:36 PM
scorpion_z28's Avatar
Default Mono Blade TB's
I've heard that there are some for LT-1's but cant seem to find them any where!
Old Jul 31, 2007 | 05:46 PM
iceman15's Avatar
doesnt AS&M make a monoblade? I think they do
Old Jul 31, 2007 | 06:05 PM
mack's Avatar
Yes they do.
Old Jul 31, 2007 | 06:10 PM
slick1851's Avatar
And there not on the cheap side...
Anyone with lower power cars using them?
Old Jul 31, 2007 | 06:14 PM
Azthrei's Avatar
AS&M does make one, i've got one on my setup.
Old Jul 31, 2007 | 06:32 PM
Red96TA's Avatar
As do I
Old Jul 31, 2007 | 08:28 PM
94 F-body's Avatar
A buddie had one and I think it cost some money, but I was told that it flowed more than the 58mm TB so if you can throw the cash than it will be worth it!
Old Jul 31, 2007 | 09:32 PM
jasonisdn's Avatar
http://www.azspeed.com/inco1.html
575 for a monoblade, i ordered one, they sent 58. i sent it back
Old Jul 31, 2007 | 09:45 PM
Ironxcross's Avatar
another 300 cfm of air flow by going monoblade? thats nice.
Old Aug 1, 2007 | 12:35 AM
TwoFast4Lv's Avatar
I got one to go with my Nitro Dave N2O plate and Hogans Direct port
Old Aug 1, 2007 | 08:51 AM
imnotplutonium's Avatar
sweet! that nitro dave plate is awesome but I did not know he made one for a mono-blade. thought it was only for the regular ones.
Old Aug 1, 2007 | 11:34 AM
Vicious95Z28's Avatar
Yeah, but the intake is a bigger restriction than the throttle body.
Old Aug 1, 2007 | 12:09 PM
chief455's Avatar
whoa - whoa! He asked about usage on "low power" cars.
What is the point of throwing $575 at 1300cfm air and the motor only can use 750cfm?
I think he's wonndering if the mono blade vs twin blade design is something to look at - not just bigger is better.
From ASM:
58 MM Monoblade Throttle Valve
1300 CFM Airflow
58 MM LT - 1 Throttle Body
1050 CFM air flow
Most guys start with a 52mm or none at all. I've read the stock 48mm flows around 750cfm and guys - including my car - are in the 12's with them.
Can't tell you the single vs twin blade advantage beside increased airflow - but sounds like a waste of money unless you have full race heads/cam/intake etc.
Good luck.
Old Aug 1, 2007 | 12:14 PM
-PEPE-'s Avatar
1300 cfm p/ASM mono specs and hell yes it is nice when the rest of the engine is built. Little overkill for a stock engine but another 1/3 the price of any other monoblade and you'll be setup for later. Paid $450 for mine.
Old Aug 1, 2007 | 04:31 PM
GIZMO's Avatar
[QUOTE=chief455]I've read the stock 48mm flows around 750cfm and guys - including my car - are in the 12's with them.[QUOTE]
That should read "less than 700 cfm and mid tens".
Old Aug 1, 2007 | 06:50 PM
chief455's Avatar
[QUOTE=GIZMO][QUOTE=chief455]I've read the stock 48mm flows around 750cfm and guys - including my car - are in the 12's with them.
thanks for correcting my numbers and further illustrating my point
