I finally got to the dyno and am happy.
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
First off I have the following mods:
stock 4 bolt block bored .030"
manley 5.7" forged H-beam rods
mahle forged pistons
new stock crankshaft(I want to see how much they can take lol)
speedpro bearigs
trickflow 195 heads (hand ported)
trickflow hardend pushrods
custom ground cam
proform 1.6 rr's
arp head and main cap studs
twin walbro 255 intank pumps
aeromotive adj fpr
motron 60# injectors
stock unported maf sensor
twin 58mm t-body (hand ported)
ported stock LT1 intake
pacesetter long tubes
magnaflow catback
2 bar map sensor
stock pcm tuned by Moe Baily (moehorsepower)
oh and a D1 procharger @ 15-16lbs of boost, pump gas and meth with 9.6 compression ratio
The results are 702rwhp @ 6300rpm
speedpro bearigs
custom ground cam
proform 1.6 rr's
aeromotive adj fpr
magnaflow catback
2 bar map sensor
First time I have heard of Mahle connecting rods?? A google search makes them sound a lot like Howards's Cams powdered metal rods and I always knew Howards was not much of a manufacturer so I have a good guess on who makes those now.
Can you offer a hint on the cam size??
Good to see someone using a good crank instead of some Eagle POS.
Nice numbers let us know when you run it.
mahle 5.7" H-beam rods
speedpro bearigs
custom ground cam
proform 1.6 rr's
aeromotive adj fpr
magnaflow catback
2 bar map sensor
speedpro bearigs
custom ground cam
proform 1.6 rr's
aeromotive adj fpr
magnaflow catback
2 bar map sensor
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
the cam is around .600" lift 115lsa duration is a secret though
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
