hp and torque rating on Spec 2
no I don't think a stage 5 would. I have my last 3+ in the car wih a pressure plate failure again in less than a year. And under 11k miles. I stepped down from a centerforce to a 3+. That is a big bad mistake.
Great insight js2...the horse is still dead by the way (lol) but thats ok, just keep kicking it (you know I am just giving you a hard time right).
Elky, considering the 150 shot I would opt for a higher capacity unit to insure that you do not over-power it. What kind of torque are you shooting to make in total? Let me know and I will provide a recomendation. Thanks,
well im not sure about torque. i have yet to have the car dynoed with this cam in it, buy Ai says it should make between 345-360 rwhp. im probably only going to run a 100-125 shot but i just wanted to be sure. it will probably be on a WOT switch. and, with street tires, 1st gear is useless at WOT without the nitrous so i wont be spraying off the line. im kinda on a budget so im just trying to wait a little longer before i go buy another clutch. i may just run a smaller shot just to preserve the clutch
Based on your description I think a 2+ would give you both plenty of capacity and great drivability. I beleive a stage 2 would hold but for someone that is going to race it regularly and hit it with a decent nitrous shot the 2+ would be a great option. Let me know if you have any further questions. Thanks!
