Baddest of the bad T56 replacement!
If you have to ask how much, you can't afford it:
http://www.emcogears.com/index.cfm?t..._profile_id=13
Saw it at PRI last weekend. Price tag was about $20K.
Andrew
Andrew
http://www.libertysgears.com/clutchless.htm
The beauty of the Emco trans is that it can be driven on the street and downshifted. Holinger makes a sequential box as well.
For the more budget minded there is the Liberty modified T56 units for moderate power levels. There are also dog ring options fro Rockland Gear that use a low angle, 9310 gear set, with 4 different gear ratio combinations available. The T56s are obviously not sequential.
Andrew
clutchless, dogring, emco, gear, gears, pontiac, replace, replacement, rockland, sequential, standard, streetable, t56, tranny, trans
