Slave?Clutch? Confusing
If this is happening to you during normal driving then its not your clutch, it has to do with your slave or master cylinder. I read the sticky in the manual transmission section labeled "sticky clutch pedal write up" or something like that. It will give you a ton of info. I read through it and did what it said.
I checked to make sure my clutch fluid wasn't low, which would mean there was a leak somewhere. I then bled my clutch pedal fluid and even used a mity vac to try to suck out any air in the line that might be causing the pedal to not come up all the way. No Air in the lines.
Next I replaced the Master Cylinder since it was a little easier to do then the slave. Note that I skipped the "drill mod" because that is for people who are having there clutch pedal stick half way up only when they are flooring it and ripping through the gears causing it to be harder to switch into the gears at WOT. After replacing the Master cylinder it was the same thing, soft mushy pedal that only comes half way up even just cruising around town taking it easy.
So my last resort is the Slave Cylinder. I should have known it was the slave because something happened to me that proved it was the slave. I was at a stop light next to a car filled with highschool kids who were all yelling at me to rev my engine so they could hear it. I had it in first and the clutch pedal in of course and start reving the hell out of it almost redlining the tach. The light turns green and when I release my clutch pedal to take off it is stuck all the way to the floor! Usually it only sticks half way up but when I was reving up it caused the pedal to be sucked all the way to the floor!
I pulled it off the floor with my foot and started pumping like crazy trying to bring it back to life. I only had like 1 inch of clutch at this point and I was grinding into my next gear. It probably took like 30 pumps to get it back to normal.
My theory is when I had it in gear and the clutch pedal down the slave was compressed as usual. But when I started reving up my engine it made the slave heat up pretty hot like any other f-body, but because my slave is bad, that normal heat caused the cylinder of the slave to bind in its bore which in turn would not let the pedal come back up. This is a direct quote from the sticky.
"The slave cylinder is what pushes on the fingers of the clutch to make it release. In the flawed part, when the clutch gets hot, the heat is transferred to the slave cylinder, causing the piston inside the slave to expand, and it binds in its bore, causing the clutch pedal not to be able to come back up."
I should have gone with my theory instead of dumping $95 for a new master cylinder down the drain, but I really didn't want to have to drop my tranny. But now it looks like I have to. I bought a new slave and will be installing it tomorrow. I have a thread about it which I will update tomorrow sometime in the late afternoon. I hope any of this info can help you, good luck!
