Monster Clutch needs your feedback!
Guys and gals,
We need more Featured Monster's on our website!
If you want your car on our website write us a small description sharing your experience with your Monster Clutch and include pics of your car, we'll get you up on our website so others can see your ride and read some feedback!
Please submit this info via email to steve@snlperformance.com!
Thanks a ton for the continued support!
Steve Addison
SNL Performance/Monster Clutch Co.
817-750-2000
Steve Addison
817-750-2000
Well the clutch held up great (level 3, 4130 flywheel) So I will send you some info/pics/review soon!
BUT-
Was at the rental today and unloaded the car, ran an easy pass (launched at 5 k, usually 6.5k) So it only gets a 1.62 60' and runs 11.13 @ 124.6 (99mph 1/8th). SO I go to launch the second time and it's fine but doesnt stay in gear, it goes in but as I let off the clutch, it spins to redline, let off gas, back on gas, grabs... Everyone is thinking it's me, it does this 5 times in a row. Next pass I 60' 1.55 but shift slowly, and run an 11.15 @ 123.4. So I go hard on it again, and it slips, but it's definately NOT the clutch, I even hotlapped 2 1.55's back to back. So I go one last time and well, boom, I assume it's the input shaft, or maybe the output shaft? Sucks, but I think it would have been an easy 10 second day had I not had issue's.
Still running patriot stage 1 heads, torquer 2, now have a fast 92, and a SD tune by kaltech. It feels really strong, and I think I can do alot better once it's fixed...
I want to thank Brian @ Kaltech for an awesome tune, and Nick 1baddls1 for helping me out today Both of them were great for getting me down the track today!!!
Seems to be a budget setup that works...
http://www.youtube.com/watch?v=JTtrd...eature=related
http://www.youtube.com/watch?v=MXyxxCOP0tc
__________________
BUT-
__________________
BUT-
http://www.youtube.com/watch?v=JTtrd...e=channel_page
__________________
BUT-
__________________
Damn good 60ft's man!
Hate to hear you broke, but, at least you'll come back stronger! This is proof that our setups will find weakness in the drivetrain, especially when you drive 'em like this!
Thanks a ton for the post!
I realize that this issue will cost you money, but, the fact that you bent your shifter tells me you get a bit excited while traveling down the 1320...
Also, the fact that you broke your 12 bolt speaks volumes for both your setup and our clutches! Thanks a ton for putting our stuff to the test, get that 9" in there and let us know what happens!
i dont mean to hijack the thread but how would this cause it to pop out of gear??? by the way once the rear goes inmy car ill be placing my Moster order...SNL we will be in touch soon
Steve, my car is in the shop right now waiting for tuning after the blower install and will be ready to punish your clutch after a bit more break in. Let me clean it up and put the Zo6's on after it's all done and I'll get you some photos. I would love to be featured on your site.
![](http://www.fquick.com/images/vehicles/full/26776246536.jpg?1238544791)
![](http://www.fquick.com/images/vehicles/full/26776241062.jpg?1236883661)
x2 on the stickers as well.
Don't blame us because your "monster" logo is cool. I want some too!
And if the shifter was bent on the lower part it could cause the gears not to fully engage, thus causing them to "pop" out.
i am in the process of putting one in my car stage 3 with chromoly flywheel. will be done this weekend and will get some pics and info out to you. will tell you it looks great and can't wait to see how it does. no worries cause you can tell what a great product it is by the feedback. thanks again.
Wasnt reall poping out persay, but I think it was a compound issue. The rear would grab and release, and made clicking poping noises. The shifter, wasnt fully engaging the gears as I went through them. When I first went to diagnose the problem, I disconnected the driveshaft on my trailer, and in gear, or so I thought, the shaft spun. I pulled the trans and had no power transmission through it till I pulled the shifter (was leaking as well) and shifted the rail by hand, had no problem, went right into gear. I was going to leave it at that and get a shifter. But I decided I should just drain the rear and change fluid. Well, the rear made no noise after the last run, and I spun it fine by hand with the wheels off the ground, so I thought nothing was wrong. So I drain the fluid and Nothing comes out, I look in the drain, and it's clogged with metal chunks. Pull the cover and the diff grenaded. Three pinion teeth missing, and it still turned w/out noise. The axles were locked to gether by chunks caught between parts but I assume it was catching and releasing stuff sporadically.
Well i put my stage 3 with chromoly flywheel in over the weekend. very nice piece. Will get some pics up on this thread for you soon. Got about 200 miles on it so far and it chatters very very little. just in pull out but i believe the flywheel being lighter could definitely help with that. Very great pedal feel. Just overall very happy with it. Highly recommended.
