removing the hydraulic line
Old 07-16-2009, 09:29 PM
2000ws6transam's Avatar
Default removing the hydraulic line
ok i have taken my trans out at least 12 times and now the plastic piece that you remove the hydraulic line from the slave looks like hamburger( i use a couple small flat heads to push it in). i went to the dealership and they cant seem to get that piece without the whole line. A. is there any special tool to remove this, and B where the heck can i find one? Does it have a special name?
Old 07-17-2009, 12:42 PM
bearcatt's Avatar
GM Hydraulic Clutch Line Disconnect Tool
Kent Moore J 36221
http://www.toolsource.com/hydraulic-...1-p-61448.html
http://www.amazon.com/dp/B000HI53LG/...0&linkCode=asn
You've got to be kidding $30.95 for those.
I got one for free when I bought a clutch one time.
It's just thin bendable metal.
Old 07-17-2009, 02:55 PM
thanks for the info! now i just need to find a new plastic piece...
Old 07-17-2009, 03:33 PM
Dal1as's Avatar
Rip the plastic ring out and buy the bushing talked about in this post. They work perfect to release the line. No screwdrivers or tool needed. Just push the bushing in along with the quick disconnect and pull it out.
https://ls1tech.com/forums/manual-tr...l#post11878390
Old 07-17-2009, 03:42 PM
bearcatt's Avatar
Glad to help when I can ... looks like Dal1as has your answer on the plastic bushing.
That's good info, a little part like that would be difficult to find otherwise.
Old 07-17-2009, 04:52 PM
awesome i will get to reading that article thanks guys!
Old 07-18-2009, 09:01 AM
i ordered it last night with the help part # its a bushing for brake and clutch. Cost 8.00$ at auto zone. It will be here tues. so i will see how it works!
Old 07-18-2009, 04:47 PM
bearcatt's Avatar
Did you get the line off ?
Old 07-19-2009, 12:41 AM
not yet, dont have the money to fix it yet, i will do it when the parts come in on tuesday! Seems i have bad luck up here in MI. i get 3-4 mo. to drive the car and something brakes on it almost every summer. sometimes i wish it was still stock..
Quick Reply: removing the hydraulic line
