Clutch pedal pressure
I've searched ls1tech for a couple of days and haven't found much, my pedal will get pretty stiff while I'm driving, it doesn't stick or act like its going to hang up any, just stiff when I push it down, if I put the car in neutral and pump the clutch a couple of times, the pressure of the pedal goes back to normal feel. Any ideas?
Well, no offense, but you did not search this forum for a couple days if you couldnt find that info
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
This forum is FILLED with these threads.
You have a hydraulic issue. First, basics:
How old is setup? Clutch? MC? Etc...
2nd..have you checked fluid? Color? Bleed it yet?
When you say "broke", how do you mean?
Then, after you replaced MC, did you have this problem? Was it present BEFORE you replaced MC? When did this start?
Very good chance that the stock slave is on it's way out, but first, if you can answer teh above questions...
It was working fine, then the MC started leaking internally, so I replaced it and the pedal felt fine, except when at WOT of course. It started doing this stiff stuff a couple days ago, the clutch still grabs in the same spot, it just harder than normal to push down.
