mcleod street twin rebuild lt1
hi my street twin has recently started to slip pretty bad. prob mostly my fault cause i was still letting it loose even though i could feel it slipping pretty bad. recently it started slipping really bad so i dropped the trans out and pulled the clutch. the discs were worn all the way down to the studs and the fly wheel and center plate have some grooves in them. the question is could i just buy the pressure plate somewhere else since there all the same and have the center plate and flywheel resurface and just buy new discs opposed to spending 1300$ on a whole new set. or can the company rebuild these for a reasonable price.
We offer a complete rebuild for $450. The rebuild includes the following:
replace p/p, replace disc lineings,resurface floater plate, resurface flywheel, reshim & check for release. Fill our a RGA form before you send it in
http://www.mcleodracing.com/forms/rga_form.asp
